How many vectrix reached 30.000km?
224 posts / 0 new
kingcharles
kingcharles's picture
Re: How many vectrix reached 30.000km?
Have you installed The Lairds software already?
Better to do that before you start shorting cells.
kingcharles
Wildfire
No, I hadn't installed Laird's firmware yet as I've been waiting to secure a couple of reliable outlets at work for recharging. My usual outlet has a "flaky" GFCI that would randomly trip out; with the Laird's software I would conceivably have never gotten a full charge as the circuit would have probably tripped during the pre-charge cooling operation. This issue is now solved to I'll probably do the upgrade sometime this fall.
kingcharles
It is actually the other way around. There is no pre-charge cooling but post-charge cooling.
With The Laird software you are charging at a much lower power rate so there is also less chance of tripping a breaker. The power rate is actually almost 50% lower than the standard Vectrix software!
Last seen: 11 months 5 days ago
just passed 50'000km
Last seen: 2 weeks 2 days ago
46500 km! I'll catch you.;-)
grillino75
ciaooo!!! last 9000km with TENNICO lifepo4 kit.
M.Chen
Vectrix is really good quality mechanism,still brand new after 709320kms,amazing machine !
Frolle
Impressive!
To still my curiosity, how many battery packs / replaced cells was spent during the first 60.000km?
Still the original parts in the gearbox?
Any issues with the motor controller?
Where on the globe do you live? Thinking of the climate where all those km was ridden.
/Frolle
grillino75
I changed a battery pack after 12,000 km and the last package I have traveled 50000 km was still accurate and efficient 65km at 65km/h. I put Lifepo4 'cause I wanted more' autonomy.
I changed the encoder and the fuse.
everything else ok
I live in Rome, Italy
PS. with 41 cells the notches were very wrong .. now with 42 cells (few weeks) the notches seem much more 'true .. estimate range 90-120km ..
ciaoooo
Congratulations Grillino!
woowwww 70.000 km! You're approaching the (over)estimated life of the Vectrix's original battery: 80.000 km.
Have you made the conversion of your vectrix by yourself? What cells are you using in the conversion?
pyjohnson
Thats my battery pack (the 3rd one) reached the 30,000km mark, the rest of the bike is 6,000km in front
Regards,
Peter
Central Scotland
Rtmopar85
Not close yet only 750 miles on one. 1250 miles on the other. Still in mint shape. Does make it hard to keep the batteries up to shape but I ride them around the neighborhood. It's about time for another toy. Anyone have interest in a his and hers pair in Georgia?
2008 and 2007 Vectrix VX-1
tried to get all 6's on the weekend, but didn't pull over fast enough:
