Just finished a discharge run on 2 24 volt evercel Nickel-Zinc pack , they are rated at 30 A/H
Equipment used : A/H and W/H and time = Yokogawa WT200 Wattmeter
electronic load 5 Amps = Kikusui PLZ303W
Hybrid recorder = Yokogawa HR2300 30 channels
Cut-off = 38 volt
Result are : 31.95 A/H ; 1,457 W/H ; 384 minutes
Very interested to know how those figures compare with the Guineng Silicone Battery , the VRLA or even the 8 of the EB20-12 pack .
The very low impedance of the Nickel-Zinc (less 2 milliohm /cell ) allow for very quick recharge in about 2 hours , the charger has to be a
CC-CV with BMS highly recommended .
were can I get these cells?
I cant find them any where!
Would a 12ah Nickel-Zinc cell be the same size and weight as a 12ah lead acid gel cell?(if so, do they make them?)
How heavy is your 30Ah battery?
I read that these cells self discharge them selfs, so would storage be a problem?
How much would a charger for these cost?(a nice one but not over kill, ya know?)
The stock reports on the companies that make the chemicals and metals, say very good things about these batteries. You can give Nickel-Zinc cells more punishment then lead acid cells can take. If I can get these for my Pocket bikes, the high discharge rate would be a bit handy.
I just Re-laced my first spoked wheel! and it was trued by spinning it in my hand
Yes more information about this pack, such as SIZE, WEIGHT, and COST. I would think that they would be comparable in WATT/HOURS with the STOCK E-max Battery. Please let us know. Thanks and God Bless :)
Evercel MOD40-12 2 Modules Part MOD040-7B 28 Volts 30 A/H brand new Battery in original box . Made by "Hiamen Three Circles ERC Battery Co Ltd China ISO 9001 ,yields over 30 A/H & 700 Watts/Hours capacity measured with 10 Amps load .Original OEM price of this battery $ 395.00 W: 17.3KG Dim: 360mm X 200mm X 200mm. Chart recorder chart showing discharged and power data are available for SERIOUS INQUIRY ONLY . 1 year guarantee .Was told that they where designed especially to be used on Lepton scooter ,the boxes are marked either " Front " or Back .Competitive pricing with other chemistry .
Those batteries are new and expected to deliver over 500 cycles 100% DOD
Lastest discharged at 5 amps electronic load yield 34 A/H and 1550 W/H for a double 24 volts pack , cut-off at 38 volts ( 1.36 V/ cell )
measured about 2 milliohm per cell (Agilent HP4328A )when fully charged .have been able to recharge them at 18 Amps to 2.050 V /cell within less than 2 hours they took about 36-38 A/H .
Have yet to heard from anyone about the silicone pack that came with the E-Max ,has anyone ever really analyzed those batteries , A/H , impedance etc.....
Can be reached at (203)627-8426
Andre
here
Anyone got one they might want to sell?
My KZ750 Project: here E.T.A. 1 mo
