Soldering and desoldering
![reikiman's picture reikiman's picture](https://visforvoltage.org/sites/default/files/pictures/picture-30.jpg)
Soldering is a way of joining wires together by melting metals so they stick together. It's related to welding but occurs at a much lower heat and does not join the metals together.
Soldering is defined as "the joining of metals by a fusion of alloys which have relatively low melting points". In other words, you use a metal that has a low melting point to adhere the surfaces to be soldered together. Soldering is more like gluing with molten metal than anything else. Soldering is also a must have skill for all sorts of electrical and electronics work. It is also a skill that must be taught correctly and developed with practice.
Soldering requires a metal with a low melting point - the solder.
- Washer11
- tespila
- CinemaCrazeX
- dbayliss
- Bikearenastore
- dpw666
Comments
Re: Soldering and desoldering
I would like to add a couple things to this list of vital basic skills.
After working on many old cars Ive learned that, if you use a dry crimp on an important electrical connection, it may last for years, but it also may eventually fail at the worst possible moment. Aluminum and copper doesn't "rust" like iron/steel, but an oxidation layer will form that causes resistance in the connection. Oxidation is worse near a salt-water environment.
"Tinning" is when you put a layer of solder on the wire tip, and then a layer of solder on the connector socket. Then after inserting and crimping the two, you heat them both to connect the solder skins. The outsides may oxidize slightly over time, but the internal connection between the two will be solid.
Because I sometimes pull on a wire to disconnect a plug, sometimes in the past the wire has pulled out of the connector. An electrician showed me a technique where the stripped wire tip was bent in a "U" shape before it was inserted into the connector socket and then crimped. This made a very strong connection.
That was very helpful, thanks.
I noticed Harbor Freight has a helpful soldering fixture like the kind he was using in the 2nd video. I meant to buy it but forgot when I was there :(
Soldering type fixture
A small portable type vise is often very helpful when soldering.
Here is something I learned while working in a lab where we built and repaired circuit boards.
You can get solder wick at any Radio Shack store, and at many other electronic parts houses.
Dick B.
Dickey_b
Waste Not, Want Not
Basic soldering how to video
http://www.youtube.com/watch?v=BLfXXRfRIzY
