Vectrix Lithium conversion kit V2 - with some CALB 70AH shoe horned in
16 replies [Last post]
Hi Guys,
I'm finally getting ready to sell the much anticipated 70AH conversion kit
here's a picture of a nearly finnished product:
Re: Vectrix Lithium conversion kit V2 - with some CALB 70AH ...
Oops, I mean this is the kit nearly finnished installation on a Vectrix:
This is how the kit will look as shipped (with the old nimh battery container as a packing material):
This is a direct link to the picture album:
http://s283.photobucket.com/albums/kk316/antiscab/
okay, more information on the kit:
Included is:
fwx 200A fuse
42 x CM060 BMS modules + blue box
plastic cover and spacers
battery interconnects
noalox battery paste
pre-charge light bulb
Aluminium seat bracket
stick on foam tape (to be used where the plastic meets the aluminium frame)
What you will also need to buy:
cycle analyst
50mV 100A shunt
42 x CALB SE70Ah or WB60AH cells (not sure yet whether the CA70Ah cells will fit)
silicone sealant (water proof variety)
what you will need to extract from the parts removed from the Vectrix:
anderson connectors
the hook from the fan cover
the back plastic from the fan cover
What tools you will need:
torque limited drill
USB-CAN Cable
socket set
screw driver set
wire cutters
automotive crimper
soldering iron
and finally the price:
This version of the kit is US$2500 + shipping
As usual, payment is by paypal, US$1250 on ordering, and the remainder when ready to ship
I have one kit ready to go, and most of the bits ready for two more (lead time on those two is 3-4 weeks)
after that, lead time is 8 weeks
The video is still a work in progress, hopefully I can get it done this weekend
CO2
And modification charger to charge 70ah?
Looks a bit awkward to ride :)
^^^forget that...only first photo showed up initially!
Thats what you need the USB-CAN adapter for - to load a version of firmware The Laird wrote to allow the charger to fully charge a 70AH battery
Not sure why the first post only had the one photo, but oh well
I was just reading the specs on CALBs new CA series of cells:
Only the older CALB SE70Ah cells will fit and the CALB SE60Ah will not
but the new CA series, only the 60Ah cells fit but not the 70Ah
its all about the cell width, 115mm is what is needed.
just as I'm thinking about this,
THe fuel guage with The version of firmware that allos charging of the 70Ah cells does not yet work, however, the voltage is shown while riding
at least one of the people who have purchase this new kit is planning on relying on that and not installing a cycle analyst
While I don't recommend riding with no Ah count, keeping an eye on pack voltage only may work ok
The risk is the bike won't stop you from overdischarging the cells, but the voltage sagging below 120v while riding is where you would stop
Sounds easy to monitor.
kingcharles's picture
Online
I am using The Lairds software for a while now and I never look at the fuel gauge anymore. I only look at the voltage readout now. At 130V I go into conservative mode and at 120V I consider it empty tank.
It made me think that the fuel gauge might as well be used as Voltage gauge also the same way it does when the charger fails.
CO2
So full discharge is ??? 102v?
that sorta works, except most of the capacity in a good pack will be between 125 and 130vdc
on the fuel guage when working as a volt guage, that represents 2 bars - not really enough to be meaningful
full discharge is between 115v and 125v - the reason I say between is you should stop when the first cell is depleted, but you can't tell from pack voltage alone as a single cell reversing only causes a voltage drop of 1.5v
best practice is to measure the capacity of the smallest cell and scale the fuel guage AH count to that amount
The problem is actually worse with the lithium kit, as the voltage stays the same for most of the discharge.
So the voltage readout will give you an idea when you should stop, but no prior warning that an AH based fuel would
That's why I recommend the cycle analyst
If you ever get an agent who can do this conversion in Melbourne, let me know. It might just be the arm twist I need to do it.
Online
Looking at the pictures again I see only 20 CALB cells in the top layer. Are there 22 in the bottom layer?
Also, would another stacking method work for cells with more than 115mm width but less depth?
I was just looking at those 100Ah cells from the other thread and they might fit 5x3 laying and 3 high gives 45 cells.
Crazy idea or possible?
Yes, thats correct
That could work, as long as those cells don't mind being on their sides
The same approach could be used for WINA 100Ah cells
CALB would appear to no longer make the SE 70Ah cells, which is a shame.
I have found this cell that has the same dimensions though: http://www.ev-power.eu/WINA-30Ah-100Ah/WINA-LiFePO4-Power-3-2V-72Ah-aluminium-case.html
72Ah so even a slight increase in capacity.
Short URL
Customize This
