I just had to install my own motor mount adapter and I had to cut the stock controller mount off to give that little bit of space needed to fith the 12v12Ah cells in
- Bengun
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
it carves hills and grass like a champ now, almost scary fast
I just Re-laced my first spoked wheel! and it was trued by spinning it in my hand
I get her up to the 1.75hp wall at 39mph!!!!
this is with 18/80 gears
I tried to use a 22t on it but it just killed the top speed alot
pulling some dead stop wheelies to show the utter torque I get with 13/80 gears
mr_exon,
This is VERY GOOOD HardWork on Moddding your Scooter make it
go Fastttttttt 39 Mph Awesome !!! Thank from Craig Deafscooter....
deafscooter
this was a really fast build, I did all the modding the first night I had this bike. Iwas almost a bolt on project other then the motor mount I had to make and tap.
Video note:
at 00:50 of the video I nearly crash into the wall at the end of the road. My rear wheel was spinning so fast the grease from the bearings sprayed my drum break, NO BREAKS!
