Where can I locate the speed limiter on the 2008 Zapino?
3 posts / 0 new
BIGJOE
I just bought a 2008 Zapino and wanted to know where to find the speed limiter switch. Someone told me on the floor board where you put your feet, but when i opened it up it was a small DC box.
little
little's picture
Re: Where can I locate the speed limiter on the 2008 Zapino?
usually there is a connector ( two pins) out from the controller , or there is Jumper inside the controller, their use is the same, the difference is inside or outside of the controller, you can see my other reply to see the controller wire diagram, the pricinple will help you.
BIGJOE
I found it! Thanks this thing really moves!
Big Joe
