Question on Can Adapter
4 posts / 0 new
boeingpilot
Last seen: 1 month 3 weeks ago
I realize the official 'recommended' Canadapter is the Peak/Gridconnect one (the PSCAN version?)
Just wondering, with the adapter connected, can someone look at windows device manager? Does it show up as a 'COM' port? Was wondering if all they are doing is using the USB to create a serial port adapter to CAN.
Thx
Jim Lowder
Last seen: 10 months 5 days ago
Re: Question on Can Adapter
The can adapter is the only one that works, it is used to hook the scoot up to computor for diagnostics. Most of the diag software I have found prefers Windows xp. I think they cost $225 from grid connect. But look on the collaborative handbook there is a Vectrix owner coupon code
Jim Lowder
I actually just rented one from another member, although his scoot broke down and had to send it back early. If that is a option to you I will ask the member if it is ok to share his name with you. Also I installed the Lairds new software which is charging longer and cooler, and a few other bug fixes that the Vectrix firmware has
boeingpilot
Thanks to all. Sounds like scooterdiag is looking for this adapter. Too bad they didn't do this to open standards
2015 Tesla S90D
1983 Lambretta Lynx
1980 Vespa P200
