Unsorted Trash and Treasure Trove for Vectrix VX1 Collaborative Handbook
Potentially useful stuff can go into here until someone gets around to creating a book page for it and sorting it better.....
before comments
Comments
The following information is for the greater portion of the VX-1 (2007) Wire Harness.
The cable from the motor controller to the motor (encoder cable) has not been
deciphered. The text listing is the pin out and connection(s) for each of the
connectors as listed. I have tried to be accurate but...
As always I am not responsible for errors and/or omissions, if you use
this information you do so at your own risk. PLEASE verify it against
your bike/application for accuracy before making any decisions based upon it.
With that said it should be a good starting point.....
Regards,
Galago
J2 Interface Control Module
Pin, Color, Connects to, Wire, Color, Function
1, Grey, J18-9, Black/yellow, Horn Sw,
2, Grey, J18-8, Grey, Right Turn Sw,
3, Grey, J18-6, Green, Left Turn Sw,
4, Grey, J18-3, Red/yellow, Low Beam Sw,
5, Grey, J18-4, Red/black, High Beam Sw,
6, Grey, J18-2,5,7,10,, 2-Brown, Returns,
5- Blue/yellow,
7-Orange,
10-Black/yellow,
7, Black, J10/J11, Black, Left Brake Sw,
8, Black, J10/J11, Black, Left Brake Sw,
9, Black, J12/J13, Black, Right Brake Sw,
10, Black, J12/J13, Black, Right Brake Sw,
11, Grey, J19-2, White, Throttle pwr,
12, Grey, J19-1, Green, Throttle grnd,
13, Grey, J19-3, Brown, Throttle,
14, White, J5-2 GloveBx, White, Can Low,
15, Grey, J22-11 MtrCntrl, Grey, Can Low,
16, White, J3-5, White, Can Low,
17, White, J4-5 Dash, White, Can Low,
18,
19, Grey, J22-3 MtrCntrl, Grey, 12Vdc,---,
20, Grey, J22-5 MtrCntrl, Grey, Rtrn,***,
21, Grey, J28-3, Grey, Tail Light,
22,
23, Grey, J22-6 MtrCntrl, Grey, 12Vdc,---,
24, Grey, J22-8 MtreCntrl, Grey, Rtrn,***,
25, Grey, J28-2, Grey, Tail Light,
26, Grey, J28-1, Grey, Tail Light,
27, Grey, J22-9 MtrCntrl, Grey, 12vdc,---,
28, Grey, J22-2 MtrCntrl, Grey, Rtrn, J25 Trunk Light/sw,***,
29, Grey, J16/J17, Grey, Horn Output,
30, Grey, J16/J17, Grey, Horn Ouput return,
31, Grey, J6, Grey, Head Lamp Low Beam,
32, Grey, J6, Grey, Head Lamp common,
33, Grey, J6, Grey, Head Lamp High Beam,
34, Grey, J9, Grey, Front Left Directional Output,
35, Brown, J4-2 Dash, Brown, 5 vdc,
36, Grey, J8, Grey, Front Right Directional Output,
37, White, J4-1 Dash, White, 5vdc return,
38, Grey, J19-5, Grey, Right HandleBar E-stop sw,
39, Grey, J19-4, Grey, Right HandleBar E-stop sw,
40, White, J5-3 Glovebx, White, Glove box DB9 common,
41, Brown, J5-9, Brown, Glove box DB9 +5vdc,
42, Brown, J5-7, Brown, Can High,
43, Grey, J22-10 MtrCntrl, Grey, Can High,
44, Brown, J3-4, Brown, Can High,
45, Brown, J4-4 Dash, Brown, Can High,
46, Grey, J26, Grey, Seat Sw,
47, Grey, J26, Grey, Seat Sw,
48, Grey, J21, Grey, Side Stand,
49, Grey, J21, Grey, Side Stand,
50, Brown, J3-2 J1-A7, Brown, 12Vdc,
51, Grey, J27, Grey, Rear Left Directional return,
52, Grey, J30, Grey, Rear Right Directional return,
53, White, J3-1 J1-B7, White, return,
54, Grey, J22-7 MtrCntrl, Grey, 12Vdc,
55, Grey, J7, Grey, Front Position Light return,
56, Grey, J29, Grey, Plate light output,
J1 Charger IN THIS CONNECTOR: J5=Rear Temp Sensors, J2=Front Temp Sensors,
Pin, Color, Connects to, Color, Function,
A1, , , , ,
A2, , , , ,
A3, , , , ,
A4, , , , ,
A5, , , , ,
A6, , , , ,
A7, Brown, P3-2 ICM-50, Brown, 12Vdc,
A8, Brown, J6-1, Brown, Battery Fan,
B1, , , , ,
B2, Brown, P3-4, Brown, Can High,
B3, Brown, J5-2, Brown, V2SCLD,
B4, White, J5-3 J2-3, White, 5vdc,
B5, White, P3-9 Key Sw, White, Start ON/OFF,
B6, White, J5-1, White, V1SCL,
B7, White, ICM-53 P3-1, White, gnd,
B8, White, J6-3, White, Battery Fan,
C1, , , , ,
C2, White, P3-5, White, Can Low,
C3, Brown, J5-6 J2-6, Brown, GND,
C4, Brown, J5-4 J2-4, Brown, Can High,
C5, White, J5-5 J2-5, White, Can Low,
C6, Brown, P3-10 Key Sw, Brown, Start ON/OFF,
C7, , , , ,
C8, Green, J6-2, Green, Battery Fan,
J3 - AntHead (P3 listed in J1 above),
1, White, ICM-53, White, Rtrn,
2, Brown, ICM-50, Brown, 12Vdc,
3, , , , ,
4, Brown, ICM-44, Brown, Can High,
5, White, ICM-16, Brown, Can Low,
6, , , , ,
7, , , , ,
8, , , , ,
9, Grey, Key Switch, Grey, Start ON/OFF to charger,
10, Grey, Key Switch, Grey, Start ON/OFF to charger,
J7 Front Position Light,
ICM-55, Grey, J29 to ICM-56, Grey, Plate Light ICM-56,
J8 Front Right Directional,
ICM-36, Grey, J30 to ICM-52, Grey, Rear Right Directional,
J9 Front Left Directional,
ICM-34, Grey, J27 to ICM-51, Grey, Rear Left Directional,
J18 Left Handle Bar Control,
1, n.c., , , ,
2, Brown, ICM J2-6, Grey, return,
3, Red/yel, ICM J2-4, Grey, Low Beam Sw,
4, Red/blk, ICM J2-5, Grey, High Beam Sw,
5, Blu/yel, ICM J2-6, Grey, return,
6, Green, ICM J2-3, Grey, Left Directional Sw,
7, Orange, ICM J2-6, Grey, return,
8, Grey, ICM J2-2, Grey, Right Directional Sw,
9, Blk/wht, ICM J2-1, Grey, Horn Sw,
10, Blk/yel, ICM J2-6, Grey, return,
J19 Right Handle Bar Control,
1, Green, ICM-12, Green, Throttle gnd,
2, White, ICM-11, White, Throttle Pwr,
3, Brown, ICM-13, brown, Throttle,
4, Grey, ICM-39, Grey, E-STOP/KILL SW,
5, Gry/blk, ICM-38, Grey, E-STOP/KILL SW,
6, n.c., , , ,
J22 Motor Controller,
1, Grey, J14 J25 Trunk Lite, Grey, Glove Box 12 vdc,
2, Grey, ICM-20 24 28 J25, Grey, Glove box 12 vdc return,#,
3, Grey, ICM-19 23 27, Grey, 12Vdc,*,
4, Grey, KEY SW/J3-9, Grey, Start ON/OFF,
5, Grey, ICM-20 24 28, Grey, 12 rtn,#,
6, Grey, ICM-19 23 27, Grey, 12Vdc,*,
7, Grey, ICM-54, Grey, 12Vdc,
8, Grey, ICM-20 24 28, Grey, 12 rtn,#,
9, Grey, ICM-19 23 27, Grey, 12Vdc,*,
10, Grey, ICM-43, Grey, Can High,
11, Grey, ICM-15, Grey, Can Low,
12, Grey, KEY SW/J3-10, Grey, Start ON/OFF,
image_25.jpgCompare with service manual
Hello,
I'm gathering as many informations about the VX 1 to share them, without any site, since vectrix part site is dead and support site may die too.
So the service manual could help. Thank you.
