How to "improve" a NiMH Vectrix battery before it becomes damaged
Some Vectrix owners have now had their last battery replacement under warranty - and others must repair the battery themselves by replacing damaged cells - or find someone with the know-how to do it for them.
In any case, at this point it might be worth the effort of making some improvements that are likely to increase the chances for a very long battery life!
Particularly if the battery is already dismantled to cell level, one could more easily add some devices to improve battery management.
What are the options?
What is safe?
What is effective?
What has the best cost/benefit ratio?
What would be the optimum - regardless of additional cost?
CAUTION: These batteries are very dangerous! Do not do any work on them without the appropriate tools and training!
Hopefully we will be able to develop some recommendations here that could be handed to an EV workshop or electrician, so that they can build it for you if you do not have the skills to build it yourself.
Mik, you're the one.Thank you.
(I apologise for not having enough knowledge to help in this post.)
Hi, here are my thoughts:
A few starting points to get things going:
What I think is needed (in order of importance):
A) Additional cooling and battery temperature equalisation, during charging and maybe also during riding and parking.
>> Using some precooling like Mik´s ABC would be great. As the fans are connected via plugs: What about an "interconector"
between fanplug and Vectrix plug, using a "relay-switch". If you want you can run the fans from a little battery, when
the Vectrix-mainboard decides to power up the fans the relay uses the power to disconect the battery and run the fans
directly via Vectrix-suply. I´m not sure if this is how the ABC runs right now? Sorry I dont´t have the time (men at work)
right now to draw a little shemata to show what I exactly mean. I will post it later.
B) A way to gently equalise the battery with minimal heating.
>> As you mentioned in another post a plug (waterproof and save) to connect a small charger like the "universal freddy".
C) A way to fully discharge the battery to remove voltage depression and achieve full capacity and battery gauge synchronisation - without riding around in dangerous traffic like a lame duck!
>> It´s tricky to discharge the pack without reversing the weak cells. As the battery is organised in 12 packs, what about a
discharge-wiring for each pack so you could control 8-9 cells per pack, which maybe isn´t so harmful when discharging to a
low level. This wiring could be used for an equalising process too.
D) A way to detect cell reversal during discharge, for those times when the stock system misses it and damages the weakest cells.
>> There would be 2 ways: Heat and/or voltage. I tested a little circuit (Mik maybe you remember when we discussed about the BMS
on www.vectrix-forum.de)with two spare cells. One full one half empty discharging via the CBA-unit. It worked ! When one cell
was depleted the voltage was low enough to activate the circuit to show it.
+ it is a small cheap circuit about 3 Euro.
+ if one of two cells is empty it can be shown via LED or accustic signal (with an optocoppler turned on by the circuit).
+ the circuit is small enough to mount it into the batterypack, so only the wiring for output is needet (when using an
optocoppler there would be less dangerous wiring outside the pack.
/ The circuit needs 2 cells to watch, otherwise the voltage is to low and the results are not very accurate.
- you need 102/2 !51! of these circuits a lot of soldering and work to connect to the battery.
- very small but permanent current draw from each circuit.
- If one of the circuits fail, the atached cells could be emptied causing an heavy unbalanced pack.
The resisors shown are for a 12v Battery some rework is needed here.
The second way to watch the cells and their temperature using thermal resistors as the stock bms. By puting the thermal
resistors in series for the cells of each block (8-9 cells). If one cell heats up dramatically (like many from us have
seen already - me to befor my batery was reworked/fixed)the thermal resistor will change its value a circuit managing the
block could give a signal.
+ no current draw
+ it would be possible to watch each cell similar to the circuits described above, or one pack (simpler/less work)
+ It could detect low level dischgsarging (heat) and overcharging (heat)
- I don´t know yet if it works puting 8-9 resistors in series? Maybe if all cells heat up to 30°C it has the same result
like just one resistor heating up to 45°C
- Maybe if a cell heats up enough to trigger the circuit, cell-reversal could already have damaged the cell.
E) Logging of data to determine when an EQ charge or exercise cycling is needed - and to know when it is complete.
>> something like the braindrain battery-monitor? but it would need a shunt.
F) Removal of the 7mA continuous current draw during storage.
>> dont´t laught I use a similar part in my Fiat Panda Electric:
It is a fuse and a switch in one combined. By opening the fusebox the fuse is pulled apart form the contacts. You don´t have
to touch te fuse to open the circuit, but when the box is completely open you can change the fuse without riscing a shock (the
fuse is disconnectet from any part with dangerous voltage. Of course dont put a pice of metal in the open box that could be
very harmful. Before closing the box you need to activate some kind of inrush current limiter.
+ save
+ the replacement fuses are cheap and easy to get (many sizes, my panda uses a box with two 160A fuses)
+ easy to open the circuit
/ would need a ICL Circuit activated by a switch before puting the Fuse back.
- for safty it still shoult be positioned in the battery container, but it would be a better place than on the mainboard.
G) Placement of the fuse in a more accessible location.
>> See F). Another possible place: the glove-box
+ easy to open
- needs a waterproof solution
- heavy changing of the power-wiring is needet, wiring must be protected from any damage.
I´m sorry for possible mis-spellings and gramaticaly errors in this post...
greetings Mike
I´ll add some shematas and drawings when i´v had time to make them...
and maybe correct the misspelling ;-)
Here is a preliminary list of requirements for the 12V SMPS to be suitable for the job:
1) Continuous 5A DC at 12V DC without over-heating. It might be possible to mount it somewhere in the cooling air stream.
2) Isolated 12V output - essential! How do you test this?
3) Ability to be powered by 110V DC to 160V DC (approx).
4) Low standby current drain. This would not matter much if a battery disconnect is also installed.
5) Small enough to fit somewhere into the battery compartment.
6) Tough - the vibrations of on-road use are quite severe.
I'm sure there are other requirements.
to discharge the battery via an onboard DC-DC device sounds great. What about this company: Deutronic.
Might not be cheap but good quality and hits the requirements.
greetings Mike
Another question:
would it help to rearange the positions of the temp-sensors? They are always in the midle of the pack.
So the cells far away may heat up very much before a sensor may detect it: [0=cell, x=cell with sensor]
front pack rear pack /all layers as seen above
000x0000 0000x0000
000x0000 0000x0000
would this or a similar configuration help?: Putting the sensors away from the middle changing the
configuration a bit. as the sensors "feel" the temperature not only from the attached cell only, but
maybe from the cells around, this configuration might help to watch temp-rising faster and better.
It would need some soldering to get the sensorwires to the correct lenght and therefore battery
rework, but for those who have the skills / resources to maintain their batteries...
front pack rear pack / bottom
00x00000 00x000000
00000x00 000000x00
front pack rear pack / mid
00000x00 000000x00
00x00000 00x000000
front pack rear pack / up
00x00000 00x000000
00000x00 000000x00
@Mik maybe you postet something simmilar already, I´m not sure right now.
Greetings Mike
On another topic: What does everyone think about the PakTrakr and the Cycle Analyst as an additional gizmo for the Vectrix?
My Paktrakr is quite old now, however, my one draws the power for its internal processor off the first few cells in the pack.
It used to pull my Emax lithium pack out of balance faster than my BMS could keep up with it.
If you are going to get one, ask if that design flaw has been rectified.
if not, get the one designed for 6v batteries, and use a SMPS instead of the first battery to get around the issue.
otherwise it is a good product.
cycle analyst is a very good idea (I put one on *every* EV I touch).
The hall current sensor might also be worth a thought, particularly if no CycleAnalyst is used.
the paktrakr doesn't count Ah, so it will only show A.
but if you are data logging, you can integrate later for Ah for number crunching purposes.
one other thing I remember is there was lotsa noise in the data output, as the signal lines between the masters and slaves weren't that well shielded.
my emax put up alotta flak EMI wise, however, the Vectrix may not.
more stuff to try :)
but would it be possible to get a device that autonomously logs serial data for weeks or months at a time?
I'm not sure to understand, but with something like a Logomatic v2 Serial SD Datalogger you have all the info recorded inside a portable SD card:
http://www.sparkfun.com/commerce/product_info.php?products_id=8627
The web says the firmware can be customized, do you think it can be adapted to read these kind of data?
The Paktrakr:
"The Attention Your Batteries Have Been Dying For"
Automatically and continuously monitors up to 40 individual batteries in
* Electric Vehicles
* Electric Scooters
* Golf Carts
* NEVs
* Electric boats
Detects individual battery problems
before they destroy your entire pack.
Ok.. Let's imagines there is a cell unbalanced. The Paktrakr succesfully detects the problem. But how can we get that (common) issue solved? what kind of BMS for NIMH or device should we use (assuming that we cannot replace the cell)?
overcharge at 3A......
Ken Hall is more experienced with working with big 225Ah flooded lead acid batteries, where small amounts lost aren't significant.
nothing like trying to see if there are any work arounds with the hardware in front of you.
I still have my Paktrakr, ill lend it to you. (shame, I only just sent the battery off, could've saved on shipping :( )
I don't really want to be posting the schematics all over online per se as its probably Ken's livelihood here.
Hi, maybe somehow offtopic: An engineer in Tirol/Ausria made a Solartrailer for his Vectrix.
Not enough as rangeextender during a ride but he is able to recharge anywhere the sun shines.
Spreading the solarpanels, the trailer puts about 420w back in to the battery. I´ll try to
contact this guy, maybe some good input for this thread.
greetings Mike
Maybe an trailer would be an option, for short trips it is left at home, for longer trips you take it. Maybee some stuff like this:
source: Single Wheeler by www.freewheel.de
or an old Pav 40 or Pav 41 trailer. It seems a kind of replika is produced now in Canada or the USA (can´t find the Link yet)
wow thats a big boxy trailer.....I could fit 160, maybe 200Ah in there......
A) Additional cooling and battery temperature equalization, during charging and maybe also during riding and parking.
B) A way to gently equalize the battery with minimal heating.
C) A way to fully discharge the battery to remove voltage depression and achieve full capacity and battery gauge synchronization - without riding around in dangerous traffic like a lame duck!
How good a job does the latest firmware do? A local dealer (who has a vested interest in the problems being solved) told me he hasn't had anyone with the latest firmware have any problems with their packs.
Also Andy said:
http://visforvoltage.org/forum/9657-new-2007-vectrix-wwarranty-3200-usd-good-deal#comment-53377
If it hasn't been mentioned yet; make sure that it has the latest firmware installed. You can check it by turning on the bike, turning off the kill switch and pulling the left brake. The speedometer needle should show about 42-43km/h and the left LCD display should show the battery temperature and Voltage. The it doesn't the the last two things, than it's loaded with pre-october 2008 firmware, which will surely destroy your battery pack.
Latest firmware is a must!
I think the biggest problem when charging and in use is probably cells being different temperatures and even worse some cells being too hot. If the temperatures vary the charging/discharging will probably be inconsistent at best and if any cells are too hot damage some cells.
Mik, how do you charge to 80%? It might be that at 80% the charger doesn't use temperature to terminate the charge (thereby bypassing some potential problems (it would still be best to start with all cells at the same temperature but if the charger isn't using temperature rise to terminate the charge the problem of some cells temperature rising more than others should be minimized or avoided).
Will ABCool keep the cell temperatures from getting too hot and keep them equal or close to equal? If so running it before charging and while running and immediately after running (I think thats as important as during charging) should avoid most of the problems.
To fully discharge the battery can you turn on the lights or plug a load into the cigarette lighter to discharge the pack? Will that suffice for equalization?
How hard will it be to find the source of the 7mA continuous current drain and install a small switch as opposed to switching off the entire battery?
For controlling temperature before and after charging I'd consider a large fan, or swamp cooler or small AC unit on a timer. Maybe put the Vectrix in a tunnel-like box or insulated box for AC. Should be simpler than mucking with the Scooter. Might not be as effective for temperature equalization as ABCool if some cells start hot, but if thats the case using external cooling and ABCool might be best.
IMO for major pack problems the best solution will be to replace the pack with Lithium Cells and a good BMS, use an external charger and use a CA for keeping track the remaining energy while riding.
Mitch
My new battery, after 4700km ridden with it, is as good as new.
My first battery was killed by the previous software. When I got the new battery, I also got the new software, so I'm riding the new battery with the new software from the beginning of it's life.
I also follow The Laird's advices found here: http://visforvoltage.org/forum/7912-nimh-battery-problems-and-cures
Mik, when did The Laird's thread disappear from the Handbook - Battery topics?
I agree.
Hi Mik,
Thanks for your replies!
One way would be to use one or more of these RC chargers (NOTE: If you stay on the page a while you will get a discount pop-up for $122):
http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=6609&Product_Name=iCharger_1010B+_300W_10s_Balance/Charger
iCharger 1010B+ 300W 10s Balance/Charger
NiCd/NiMH battery cell count : 1-C25 series
You'd need six unless you want to do it all with one charger.
For NiCd/NiMH batteries: charging-auto, charging-manual, discharging, charge/discharge cycling and forming charge...
* Perfect protection. The iCharger has protection for reversed polarity (input or output), low input voltage, battery temperature, charging capacity and time overrun.
The iCharger also supports the “Open Format” data of the “logview” software and can display, plot and analyze the charge and discharge data by it. (See detail information about logview in the following website, http://www.logview.info)
You'd need to check the manual to see exactly what the capabilities are for NiMH
http://www.amainhobbies.com/images/manuals/I%20Charger/iC1010B_en.pdf
There are other RC Chargers that work with NiMH but someone posted that the iChargers are isolated. So if you wired the connectors you could charge/discharge the entire series pack with several chargers at the same time. I think it would be best to connect each charger to 2 adjacent subpacks.
Keeping the sun of the battery cover is the most important part (at least in Australia). Otherwise you might get a 10-20degc temperature gradient through the battery in a couple of hours. I'm planning to apply heat reflective paint to the step-through cover.
How about a space blanket, reflective side out draped over the Vectrix, with some space for air flow?:
http://www.rei.com/product/407106?preferredSku=4071060000&cm_mmc=cse_froogle-_-datafeed-_-product-_-4071060000&mr:trackingCode=1...
Hi Mik,
quite good idea, but I´m afraid if it will work in a correct way. You would need 102 cells with nearly
identical capacity AND internal resistance. Otherwise the system might set "false alarms" when the cells
are under load... An other problem could be the temp-gradient of the twelve modules. As they are in 3
layers the bottom modules get the cool air heating it up, second layer gets heated up air heating it up
too, the third layer gets warm cooling air and/or is heated up by sun radiation. This temp. gradient might
be enough to differ the voltage as two the three packs have more 3rdlayer cells...
More work but maybe more useful could be a setup where each of the 12 modules is checked, if the voltage
drops to a preset value a signal is switched on. Advantage if all 12 signals switch on the pack is empty,
if only one or two modules send a signal they may be maintained in near future...
Source: evconvert.com
Greetings Mike
