Scooter Headlights >>>>>>
12 posts / 0 new
JDELUNA
I have a 2006 Emax Sport and I ride it a lot at night. It came stock with incandecent 25watt BA20D bulbs. I have replaced it and upgraded them to 35watt Halogen BA20D bulbs but they still are very poor at night. Anyone know how I can upgrade these to better lights ?? I would like to try to put a single HID bulb in there which would run at 35watts also which is same as I have now but would be much brighter, but they donot make HID's for that bulb type. Any ideas ?? How are the headlights on the other scooters like the EVT-168, Lepton Oxygen, XM-2000, etc. ??? What type bulbs do tey use ??? Thanks for any info. God Bless :)
Deafscooter
Deafscooter's picture
Re: Scooter Headlights HID lamp
Deafscooter is Here...
Hello to Visforfriend,
My EVT SE ( asian version ) has 35 watt HID lamp inside my Red EVT electric scooter that help brightest blue-white 6500k temp color and it factory installed for special edition scooter it run off from 12 volts resource into ballast module inside head make high voltage in tiny arc lamp in headlight.....
Craig Uyeda
Deafscooter
deafscooter
JDELUNA
Re: Scooter Headlights >>>>>>
Hi Craig,
Is it possible for you to take pictures of how you mounted the HID bulb ?? I would like to do HID conversion also. Please let me know. Thanks for any help and info. God Bless :)
Gman
Gman's picture
I have the same problem with my 10 watt, and was thinking about upgrading also. PJD reminded me to check my 48 Volt to 12 Volt converter to see if it could handle that much of a increase.
He is now also now a EV Tech Advisor and as you know a E-Max owner.
Also see EVT 60 volt mod and Emax key switch replacement
Peace Out,
Gman
What is your vision for the future our growing community?
Gman
JDELUNA
Gman, thanks for your concern, but I am pretty sure I *should* be fine, as the bulb I am using now is a Halogen 35watts up from the stock incandesent 25watts and HIDs are also 35watts but as you know put out much more light. I hope this helps. God Bless :)
Last seen: 2 months 3 weeks ago
As far as scooter headlight bulbs. 45 and 55 watt versions of the standard bayonet-style bulb are available.
While I expressed concern earlier about the greater load on the DC-DC converter, I don't think it will be a problem. But, what might be a problem is the higher wattage bulb overheating and melting the plastic headlight reflector or lens.
I am nearly always riding in areas with street lighting, so I have found the 35 watt halogens to be plenty bright.
Deafscooter
Submitted by JDELUNA on Tue, 08/21/2007 - 09:16.
Hi Craig,
Yes this Craig here , this simples install Hid lamp and ballast inside your head
& 12 volts input into ballast modules make high voltage to HID Arc Lamp out
help three time brightest outlight at less current input of halogen Quartz lamp..
Here is Picture of many kind of Hid lamp & ballast modules to fit inside head
:jawdrop: Warning, if you mishandle the ballast, you will go to hospatil for Electric shock! :jawdrop:
Craig Uyeda
Deafscooter
deafscooter
Deafscooter
Here is my Close Up of HID Headlight of EVT 168 Asian Special Edition Red Electric Scooter ..
Note: this Hid Lamps Not For California legal use, Due Stricted D.O.T. Safety on Head light
Craig Uyeda
Deafscooter
deafscooter
Jerome
Last seen: 13 years 4 weeks ago
This is very interesting but pictures have disappeared here. Is it possible to post them again please ?
Are EVT bulbs BA20D too ? Where can I find this HID kit ?
kevinwest
Look on the web for LED bulbs. There are plenty. An LED's give of very little heat so you can use a brighter one without melting the mount or plastic. I have a Lepton Oxygen (electric scooter) and am looking into replacing the bulbs with LED. I suspect I will have to hard wire a LED bank for the head light. The headlamp lens is crap so I need something brighter.
Any suggestions would be welcome.
JDELUNA
Recently I just bought another headlight case to play around with for my EMAX and inserted a 50watt MR16 halogen bulb. I had to glue it temporarily with high temp silicone and I can say that it is much brighter and I like it. Problem is that at 50watts, my stock bulb is only 35watts, it may tax my electrical system, but so far it does not seem like it. I am actually going to purchase a HID MR16 bulb and ballast made by TRAILTECH here:
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3342
With this, it should only draw the stock 35watts and be much brighter, even brighter than the 50watt halogen I have now. I hope this helps. God Bless :)
Deafscooter
Deafscooter have them tooo ....
Remeber Ballast has Very High Voltage in starter ignition the HID lamp
Make sure not touch any metal inside your scooter or you get SHOCK!
Craig Uyeda
Deafscooter
deafscooter
  • Iber
  • bilal792
  • AndresV10
  • Richard Wills
