PowerGenix NiZN batteries
I just learned of PowerGenix, who is developing a Nickel Zinc battery (NiZN). It's interesting to see a new company try and develop this chemistry, after the spectacular failure of Evercel. PowerGenix is working in a joint venture with a Chinese company, and it's not clear whether their JV partner is the company which had previously partnered with Evercel. As I recall that Chinese company had survived the death of Evercel, and they had some level of rights to the Evercel technology.
http://www.powergenixsystems.com/service.php
PowerGenix Cell Specification
Nominal Capacity (at c/5 rate) 2.0Ah
Nominal Capacity (15 Amp Discharge) 1.7Ah
Nominal Voltage (1C/15 Amp Discharge) 1.6V
Specific Energy (15 Amp Discharge) 60Wh/kg
Volume Energy Density (15 Amp Discharge) 169Wh/L
Specific Power at 30 Amp Discharge 900W/kg
Internal Impedance (1,000Hz) <4.5mOhm
Internal Resistance (DC) 7mOhm
Charge Time 1.5 hours80% in 1 hour
Charge Life at 15 Amp Discharge (100% depth
of discharge)
200 cycles
Ambient Temperature Range Charge +5°C to +40°C
Ambient Temperature Range Discharge -20°C to +60°C
Ambient Temperature Range Storage -30°C to +50°C
Weight 50g
Outer Diameter 22.4mm. Max
Cell Height 45 mm. Max
http://www.powergenixsystems.com/technology.php
Benefits Comparison of PowerGenix NiZn Battery
BatteryType
Energy Density
(Wh/kg) @12A
Energy Density (Wh/L) Continuous Power Density
(W/kg)
Price
(¢/Wh)
Cycle Life Internal Resistance (mOhm) High-Rate Operating Temperature(°C) Comments
(NiZn) 60 170 >900 30-50 100-500 <4.5 -20 to +60 Exceptional performance, no memory, long shelf life
NiCd 40 135 600 35-60 100-800 >5 -30 to +60 Very toxic, memory problems
NiMH 38 135 600 40-60 100-800 >5 0 to 50 Limited temperature performance range, expensive
Nickel-Zinc Battery Company Targeting Hybrid Electric Vehicle Market
IbeRKT
Re: PowerGenix NiZN batteries
Is that the same as these btteries?
Photo Sharing and Video Hosting at Photobucket
I found them on the Falcon EV website(http://www.falconev.com/batteries.html) and I was wondering if they were worth the money.
That's kind of my question tooo... yeah, they're the same chemistry. But the company names are different (Evercel != PowerGenix) and the corporate locations are different (Connecticut != San Diego) and the management teams are different and ...
FWIW there were a lot of problems with the Evercel batteries. I have no idea what it takes to keep them reliable.
preps
Last seen: 18 years 7 months ago
PowerGenix is NOT Evercel or any incarnation of the former company. I work for PowerGenix and have since the start of series A funding. We have never had any relationship with Evercel or their former contract manufacturer. PowerGenix's current CM is a Chinese company called Corun. This is publicly available information. There are no ties between Evercel and Corun or PowerGenix.
PowerGenix cells are cylindrical while Evercel's were prismatic. PowerGenix does not use the same underlying components as Evercel, it is a completely different design.
Welcome, and I am glad you have made this clarification.
I just looked over the powergenix website again to reacquaint myself with it. It appears that it's not possible to buy the batteries right now, is that the case? Is there any timeline when they would be available? Are there plans to make them available direct to the public?
