Nimh Battery pack short circuit
4 posts / 0 new
Ian
I short circuited a 9.4v nimh battery pack made up of 8 cells due to not paying attention when wiring, for about 3 seconds the pack was connected wrong way. the pack is made up of a 2.4 plus 2.4 and 4.8v pack in series, (all the cells are the same). I was only only alerted to my mistake by some smoke coming off the terminal of a 2.4v pack, so then I immediately disconnected. Does this automatically mean permanent damage to all of the cells? I have a 9.4 smart charger for the pack, and a voltmeter.
LinkOfHyrule
LinkOfHyrule's picture
Re: Nimh Battery pack short circuit
Not necessarily. They're probably fine. Try to charge them up; the smart charger should let you know if there's a problem. I don't think there will be, since the weren't shorted for very long.
Brock
Brock's picture
If you can charge them individually that would be best to see if anything odd shows up. I doubt you will have an issue though.
Ian
appreciate the feedback - charging the pack with smart charger worked fine today and voltages of individual packs ok as well
