Li-FE for bicycle alternatives
14 posts / 0 new
I want to get my Electrified Electra Townie on the road.. it's got a Wilderness Energy 36v brushed w/ 35A controller. In the past I've used NiMH batteries but didn't get satisfactory performance.
I contacted YESA .. according to their site their 36v 20AH pack is the most appropriate. Unfortunately the cost they quoted is nearly $1000 and my eyes are bulging.
I'm thinking about options before I plunk down for this. Batteryspace? LifeBATT? DeWalt? Milwaukee V18? PingPing? Others?
I know DeWalt rather well having fiddled with them before. I got frustrated with all the fiddly bits and don't really want to do them again. I'd done some research about the Milwaukee V28/V18 and it looks promising, especially as the connector is readily available so you can wire them up to a non-Milwaukee thingy. The problem with the DeWalt packs is that DeWalt doesn't sell the connector.
NickF23
Re: Li-FE for bicycle alternatives
Thats a lot of money. 20AH is a lot of range, perhaps a good deal if you need that much. Here's a couple of good deals on ninh/nicd if your willing to give them another look. 36v 8AH 5C nicd $250. 36v 18ah 3C nimh $690.
www.ebikes.ca/store
Hmm, my experience w/ NiMH was using a) a pack built from D cells, the rated max rate of 10A meant my 35A controller stressed the batteries, and they didn't work too well, and b) SubC cells, the pack was rated for higher current but lots of small cell'd packs meant lots of fiddly bits. Now that you mention it the people who used F cell packs were happy with them, and they do have a higher Amp rating....
The reason for getting a quote on YESA's 20Ah pack is their 10AH pack has a lower max current capability.
Here's what I see at Batteryspace...
36V 13Ah (3x10xF) NiMH Battery Pack with Three 12V Smart Chargers for E-bike: "max rate for discharging" is said to be 40A, which would be sufficient. $589 It means using three chargers, one charger for each 12v substring. e.g. a bank charging methodology.
In Li-POLY they have High Power Polymer Li-Ion Module: 37V 20 Ah (740 Wh) 50 Amp Rate for $959, and Hi-Power Polymer Li-Ion Battery Module: 37V 10Ah ( 370 Wh) 40A Drain Rate for $450. Of course LiPOLY has the capability to explode...
In LiFEPO4 they have Hi-Power LiFePO4 Li-Ion Module: 12V 20Ah ( 4S2P Flat Pack, 240Wh, 45A rate ) Prewired with polyswitch for $379, I'd need three of these plus chargers.
This sure puts YESA's price in perspective.
IbeRKT
I guess that is why they put them in a "Water-proof / Fire Retardant Enclosure"
You don't want to be sitting on those if they explode.
Aerowhatt
Aerowhatt's picture
I'd consider the Ping battery. You could get 36V 20AH for about $500 with BMS and charger. The BMS while not that elaborate, is effective. The high Amperage disconnect of the BMS is set to just over 30 amps. If that isn't enough amperage for your application, it's pretty easy to change by adjusting the shunt resistence with a couple of copper threads. The cells used are rated for 2C continous and 3C peaks. For a 20ah pack that's 40amps and 60amps respectively. I'm testing one as a range extender on my Viento. With the High current cut off set to ~60amps the battery is performing real well after just a couple of test rides. Max amperage peaks have been 58 and the full speed on the flat amperage from it is about 22amps (just to give you an idea of how hard I'm pushing it).
Time is the only thing that will tell if these batts are a good value, or too cheap to be any good. So far except for the duct tape I'm pleasantly surprised by the build and performance of the pack itself.
Aerowhatt
Ian
I have the 36v13ah from batteryspace with 3 chargers. I think the pack is good, safe and solid, and can recommend it for the smaller size motors say constant 400w. The Chargers need fan cooling. But over 16amp draw it noticably sags, my max amp was often about 22amp for 31v. So if you need a regular 30amp to 40amp discharge I think this pack is too weak, you'd want to double up.
Anyways to fix this for my bike I have added 8 more cells to another 9.6v which is perfect for my motor, and voltage sag is not an issue as I rarely go over 15amp with 46V.
proton
proton's picture
A 20Ah pack means you want to go 25 miles
If not, try a 12Ah pack
falconev
A 20Ah pack means you want to go 25 miles If not, try a 12Ah pack
Well, yes. 20AH means long range, longer than I need. However Yesa's ratings are as follows. The 10 AH pack does not have ratings that match the controller & motor on my bike. If you have some alternatives to suggest please let me know.
  10 AH 20 AH
Standard Discharging current 5~10A 10~20A
Max Discharging current 10~20A 40A
I see this page .. http://falconev.com/batteries.html ... however the page is a total confusion and it's hard to tell what is included or the characteristics.
On http://electricrider.com/batteries/eonyx.htm they are selling a battery they say uses the same technology as the A123/Dewalt batteries. Today they're offering a 20AH pack for well over $1000 and they're describing a 10AH pack for a much more affordable price but it's not available today. Instead it's promised for June 2008.
Texas Electric Bikes carries a 36v 20AH pack .. http://www.texaselectricbikes.com/catalog/lithium-polymer-battery-volt15-hour-p-165.html .. It's Li-POLY (hence not of the safe chemistries) and at $749.00 but that's w/o the $99 charger. The ratings are in line with the needs I have.
They also have a NiMH pack based on SAFT cells. http://www.texaselectricbikes.com/catalog/nimh-series-battery-p-168.html But they don't give the max discharge ratings.
Hmmm... Cyclone .. http://www.cyclone-tw.com/lithium.htm .. has a pack made of some very familiar looking batteries ;-) .. 10Ah48V LiFePo4 battery pack in bag+3A charger for 1000W kit ( 3.5 hours) shipped to the U.S. costs $658 ... hmmm...
electricridefl
Hey dude! I just got done commute on 20a 80v ebike for 30+ mph, no problem. I bought 3 ping battery, 36v10ah...(a little thicker than 7ah sla battery, weigh 8lbs each, assembled with flat foil cells, rigid inside, bms included, charger included...I cut the 4950mah, 3.2v cells apart to single cell series, same size as 36v10ahlifepo4 11.8"x 4.5"x2.8"...I remove bms, and ride 5mile to work and charge till green light with supplied charger, I checked amps, read 1.33, so it 1.5ah 40v charger, and then I ride home today after 4hr charge (1/2 in parallel). The battery perform flawless ubder 20a load, no bms, and measure 39.6v per1/2, same as 10mile trip with 72v ping batteries, I'd guess at 2/3 capacity, So these batteries perform super with the smallest size and weight, the cells are perfect size for bike, cells flat take up less space...but of course the best part is the price! About $250 ea delivered quickly...the chargers have 3prong (not xlr, but chinese) but there is no chrger receptacls, but complete system, high power, my guess is the 2c current cutout could be bypassed easily, by running the negative power wire from the battery, instead of up through the amp cut out, then the charging bms, still there, and switch back negative through bms...I have been running the single cells at 20a ea, 4c, ping said they could do 5c, they can...but, after my riding today, the cells got a little warm, nothing hot, just warm, I see that these cell can run 20a with no detectable peukert thingy...I had been thinking about the drill batteries, and all the hassle , and expense, and these ping cells are flat and square, not cylinders, and bms and charger,,,plug and play! And then I found out because the battery is so much less dense than lead, I made easily a clip on battery, and put one in the basket, as won't bounce around like lead chunk...so I say get ping for either correct amp bms, or try a bypass switch for neg for 4c max, won't hurt the battery, but one could use 2 of these 36v 10ah and bypass the cut off, and I would see no reason for battery malfunction, but its cutting close ...Anyhow, I have no bms for charging or discharge, all the cells are maintaining perfect balance so far, a $250 battery or %500 for 36v 20ah, and he made mine configured to my size...They work great! No more invisible power fade from weak sla battery, these things are so much fun! My bike goes so fast, there is no way I could hold the throttle on ...so I just gas and coast, the bike is so light now, I cannot whelie like before with sla battery, but man can I take off...all the way to 33mph...I wouldn't recommend remove bms...it was just too many wires for me, but now that I've seen the insides of the battery, looks like an easy bypass...I connected my battery to 250w scooter, It was hard to go , as bms continually cut on and off from way over 20a draw, so didn.t hurt anything, so this great price for an excellent performing battery...now I've got a bunch of extra batteries...Ok, now finally, everything is available to make a nice ebike...020.jpg The battery rocks! 80v, 2hp, good for 7-8 miles?
jimshoprat
How much do the cells cost & where can I get a BMS for
my 36 volt battery pack??
