Badsey scooter question
JDELUNA
Does anyone know what kind of motor the Badsey EMX scooters used ?? How many watts were they, who was the manufacture, model number, etc. ?? Again thanks for any info. God Bless :)
Gman
Gman's picture
Last seen: 18 years 9 months ago
Re: Badsey scooter question
BADSEY RACER EMX ELECTRIC SCOOTER
1500 watt DC Motor - Badsey 1500w Motor - Badsey Racer EMX Motor, Badsey Hybrid Motor, Badsey Cruiser Motor - OEM Replacement Part - Band Mount $355.00 USD
Peace Out,
Gman
Gman
Roadrashhurts
Roadrashhurts's picture
The Badsey motor is a Bosch part number 0 130 302 001. It is rated at a continuous 750 watts with peak watts up to 3500 under stall conditions. Check out the link....
http://www.teamdelta.com/products/prod5.htm
Cost is $236.50
Deafscooter
Deafscooter's picture
Last seen: 18 years 11 months ago
Deafscooter is Here...
the motor is 750 watt at 24 volts
that badsey use 36 volts as push voltage make 1500 watts
because often burned winds wire on armature
if too much push throttle
that why often bosch motor has very few rewinded on armature ..
the shaft threaded is left handed with
9 tooth sprocket on #219 chain...
the brush plate setting is advance timing...
badsey done many problem on motor to often burned ....
deafscooter have better motor for all badsey emx scooter
it has true 4000 watts at real 32 volts as loaded from 36 volts unloaded on battery ...
I own more than 7 badsey emx scooter...
craig uyeda
deafscooter
deafscooter
kmesmer
Last seen: 18 years 8 months ago
HI,
I am interested in your motor suggestion. How do I get one? Thanks Craig
kmesmer,
Please note the date of the post you are replying to. That is a very old post from August of 2007. Just thought I'd let you know that user is no longer here.
Chas S.
VisforVoltage
