electric scooter controller wiring
4 posts / 0 new
myzter
Hello
I need some help here,
controller is similair to this model:
the wiring is causing some issue..
the wires from left side to right
blue, red, red, black
which ones connect to motor ? (red/black)
which ones connect to battery ? (red/black)
also connecting charge plug wires with 40 amp fuse
any ideas or help would be great !!
nasukaren
nasukaren's picture
Re: electric scooter controller wiring
Yikes! What a mess! You didn't get it with any of the connectors? These are often a huge help in decoding the inputs / outputs.....
I think the red/blue is the motor (brushed) and the red/black next to it is main DC battery power, but the rest is a mess. Worst comes to worst, you might need to open the controller up and have the Gurus (Fechter, etc.) peer inside.
Karen
myzter
hi thanx nasukaren
I could have added this to my original post.
The mess of wires except for the four wires on the left are connected with connectors, they are not any issue.
The basic of the problem is the first four wires, they are (previously) working, they must connect to four other wires which are from the battery/motor.
So far I have tried the comment you've made, with the following the result:
- red/blue is the motor (brushed) and the red/black next to it is main DC battery power
This will result in the motor engaged full output. My ignition switch is being totally bypassed/missed, also the throttle is not engaged/working. Even though the throttle and ignition are wired up properly.
goodnslo
I think you see the problem and dont realize it.
Assuming that you wired it up correctly (which it sounds like you did), the motor goes to full "ON" meaning that the controller is shot and stuck in short. To confirm this get a multimeter and disconnect the batts and motor from the controller (ENSURE THAT THERE IS NO POWER AT ALL ON THE CONTROLLER). Do a continuity check on the positive sides and then on the negative side. If BOTH show a path (usually it is just the negative that does), then your controller is trashed and get a new one.
If it doesnt show a path on the positive side, then you need to confirm if both the ignition switch and throttle are shot (or wired incorrectly which we will need more info), OR the control sensing function inside the controller is shot (which still means that you need to get a new controller).
I have not been following your previous thread, so if you can post it, I might get some further details.
