Last night I went to a soccer game. I locked the charger inside the seat (yes,yes I know i am not supposed to do that). Anyway when I came out of the game I wanted to see that beatiful green light telling me my scooter was charged. but there was not a green light or red light lit. Also, it was very very hot! I checked the fuses in the charger and the one that is next to the lights was toast. Today i went to buy new fuses.. Everytime I put one in and plug the charger inside the seat I hear a zap (no pun intended) and the fuse burns. My question is do i have a bad charger or did i screw up my zapino? What should I do????
- Norberto
- sarim
- Edd
- OlaOst
- Iber
Sounds like a toasted charger to me. They need some ventilation.
do you think zap will send me a replacement under warranty? If not, where can I buy a speed charger?
Zap replaced my charger within a week. After a month of good service it stopped working and tripped the circuit's GFCI. The new charger looks the same but is .4 less amps than the 5 amp original. Zap may tell you that you have to return the broken charger before they will ship a replacement. Don't put up with that nonsense. Tell them that you will be submitting a warranty claim for the batteries that are fully discharged and can't be charged until you get the replacement battery charger. That seemed to change their mind about shipping the replacement charger out before getting the broken one.
Steve Tanner
I appreciate the advice but why would I submit a warranty claim for the batteries?
It is my understanding that if you leave lead acid batteries fully discharged for an extended period of time it causes irreversible damage to the plates in the batteries. Without a working battery charger, there isn't a way to charge the batteries.
Steve Tanner
Have there been any other failures of the Zapino String Charger? I have never used mine as I have had Bank Charging Installed from the beginning. I do have the string charger under the seat for opportunity charging, but so far have not needed it.
Robert Dudley
E-Scoot Tech
Just wanted to let you all know it was my charger that I fried. I called Zap! and in under a week I had my new charger, free under warranty. I am very happy with this service!
