Thundersky w/ monitoring only?
7 posts / 0 new
In http://visforvoltage.org/forum/4325-kasea-ze2000-battery-replacement#comment-24914 Matt described his battery setup using thundersky batteries and what I assume is thundersky's BMS...
He said it's important to ensure to not over charge or over discharge .. sure. I've been pondering whether it might be sufficient to have a good battery monitoring system without the rest of the BMS. The thundersky BMS is expensive but the paktrakr comes in a form which works with Li-ION batteries and it is an excellent per-cell monitoring system. With the paktrakr you can easily watch pack voltage and/or cell voltage and see if the cells are out of balance or if the voltage is going low.
dogman
dogman's picture
Last seen: 16 years 13 hours ago
Re: Thundersky w/ monitoring only?
Sooner or later you will forget to watch and oops. At least you need a good LVC.
Just a bit of clarification,
The BMS im using isnt made by thundersky, only the cells are.
The BMS i sourced from a 3rd party (who happens to deal in thundersky batteries):
www.evpower.com.au
I dont have any experience with the BMS thundersky offers.
A note with using the Paktrakr, it has a permanent 0.009A load on the first 3 batteries of every 8 string unit.
This pulls the pack out of balance by 0.2AH per day.
If your BMS cant keep up with this, then you will encounter problems.
fisher727
I had Thundersky and evpower price a bms unit for 50 lithium batteries of 90 amp hours to be put in a car. They both want a lot of money for the system $1725 for thundersky and $1418 for evpower. How much was you system from evpower.
Eric Fisher
www.SiliconeBatteriesUSA.com
Hi Eric,
the BMS for my car set me back around $2700 for my 90 x 90AH cells.
the BMS for my scooter set me back $750 for my 15 x 40AH.
fisher727
Are the BMS systems both from evpower.
By the way what type of car do you have I have a Force Solectria and it would need I guess 50x90AH cells.
I am trying to get a large purchase order together in an at cost arrangement thought my battery company for the thunder-sky batteries.
Eric Fisher
Hi Eric,
im converting a 1987 toyota mr2.
i wanted it to be reasonably fast (0-60mph in 7sec or less), and the only way to do that with thunderskys is to have a really big pack.
I have a friend who has a 240v (75 cells) 200AH pack in his ute, and thats fairly powerful (0-60mph in 6sec).
Yes the BMS for both my bike and my car are from evpower.
EDIT: misread the question the 1st time round.
