Making high current/voltage battery cables for EV's
lennonrodgers
Hi All,
I put together instructions on how I made the battery cables for my electric motorcycle - though it is general for all EV's. I made a soldered joint, which does not require a crimper. I am very impressed with the strength of the joint.
http://lennonrodgers.googlepages.com/cables
For more: www.electricmotion.org
Best,
Lennon
LinkOfHyrule
LinkOfHyrule's picture
Re: Making high current/voltage battery cables for EV's
Except for the hole thing, that's exactly how I do my Andersons. Works pretty good, doesn't it? ;)
Last seen: 1 year 1 month ago
You're missing out on the fun of wailing away at something with a sledgehammer!
That is, for my heavy duty cables I use a bigger sized crimp tool along with a 2 pound sledge hammer. It works pretty well but there is this lingering concern about the quality of the electrical connection. On this site we'd had a debate last year with observations that a soldered connection forms a complete electrical connection but a) the pictures shown as 'proof' showed only one crimp point, b) there's a contention that when solder wicks into a cable it will be made more brittle.
When I use my crimp techniques I always make sure there are multiple crimp points. For the heavy-duty cables I wail away at the cable, turn it a partial turn, do some more wailing, move it forwards or back in the crimp tool, wail some more.. the point is I'm pounding on 3 or so points of the lug. That's gonna be a better connection than if there was only one crimp point. On the other hand, obviously, it's not as complete a connection as solder no matter how many places I pound on the lug.
The other thing is about brittleness. When you solder a braided wire, solder wicks up the wire a ways, and the wire becomes stiff. What happens if your cable needs to bend near the end? If the end has become stiff due to solder then it won't be able to bend.
lennonrodgers
The cables are a bit stiff at the end - but they work great - even for some fairly sharp bends.
LinkOfHyrule
IMO, if it has to bend sharply near the end, you need more cable. And the real trick to this method is to work fast. Feed the solder faster than it can melt, in particular. Should feel kinda crunchy if you're doing it right.
sgmdudley
I was thinking about making new cables for my Zapino. I plan on using Marine Battery Cables 6awg.
They come by the foot in various colors. This site also has the lugs.
http://www.danamarineproducts.com/BatteryCables.htm
Robert Dudley
E-Scoot Tech
