xb-500 help
so my xb-500 is going through alot of problem
fist the rear wheer wires got snaped because the axle spun
then when i was pulling on the throttle a fuse blew out
while my friend was trying to fix the motor
i fixed the blew out fuse and everything was working
its just the matter of connecting the motor back to the scooter
then when i connected the motor to the scooter the fuse blew out again
causing the fuse intput to melt so now i have to get a new one
..so what could be the problem here..the motor? or the controller?
More likely the wires from the controller to the motor(the ones that got snapped off -or together) have to be properly isolated from each other and the metal from the hollow axle and the motor housing.Probably the three thick wires.
AztecFemBone's picture
Hmmm . . . sounds strangely familiar . . .
