Need rear pulley/sprocket
patm0007
Adapting a electric motor kit from a Razor scooter to my mountian bike. Need a rear pulley to mount on rear wheel. the pulley on the motor is for a belt drive ( flat belt with grooves).
Need a inexpensive rear pulley about 5 in diameter that I can attach on rear wheel.
Or I could convert to sprockets and chain.
Does anybody know where I can buy either one? I've searched the WEB but no luck yet.
Appreciate some ideas
Pat
Picture of my wilderness BD24 running at 36V. Just passed the 500 mile mark and all's well.
patm0007
Re: Need rear pulley/sprocket
Found sprockets on Electricscooterparts.com but wouls like to run it using the belt drive. They show the front " COG" that I have but not the rear drive pulley
Also would be nice to have a freewheeling pulley
Any Ideas besides just buying a kit ready to go?
Last seen: 6 months 6 days ago
patm0007
Thanks for the info, I'll check out the website
Pat
ruprek
If Mc Master Carr doesn't work out, try Northern Tools. I don't have the spcific web address, but Google should get you there. And if all else fails, check out some of the go cart supplies under sprockets. There's a whole world in sprocket, pulleys etc. Good luck.
