What voltage do the Vetrix indicator lights require?
2 posts / 0 new
In case you have the panels apart or nothing better to do: Could you measure (or read the print on the back of the indicator LED's if there are some) the voltage supplied to the LED's and maybe the current draw as well?
I would also like to know it the voltage is applied intermittently or if it is constant and the blinking gets generated in the indicator lamp itself, like in bicycle LED's etc.
I want to add Hazard Light functionality to the Vectux, maybe in conjunction with a "sub-string-recharging-BMS" described here: Can a Switch-mode power supply charge cells inside the battery by which it is being powered?
Because the Vectux cells are still being analysed and reconditioned I cannot fire the indicator lights up myself at this stage.
mikemitbike
mikemitbike's picture
Re: What voltage do the Vetrix indicator lights require?
Hi Mik, im sorry, i can“t help you with the needet voltage. The blinking seems to be generated by the controlboards (at the startup-sequence they are active for several seconds without blinking)
Greetings from Austria to Australia
Mikemitbike
