My Ebike conversion to XB-600 parts
Hi to all members of the Visfovoltage community !
I'm on a big project right now, and I want to share it with you. It's not over yet, but I'm working Hard to get it done.
I bought a Used 48V Luyuan Bike that look very similar to the XB-600. The Bikes worked for about half a kilometer before it dies completely. I knew the bike was broken, and I wanted to make a better bike by buying parts over the web.
The bike as two batterie pack, one 14amps/h and one 7 amps/h. The 14amps goes under the feets and the 7amps goes under the seat. The charger Is construct to charge the two battery packs independently, and I plan to use it that way on my modified bike but I want to be able to use the two battery packs in parallel when I'm riding...to get more amps to the controller.
That's it for my first post !
Here are a few pictures of the original bike
- Gendronw's blog
- Skyhawk 57
- wild4
- justinsmith07
- Juli76
- xovacharging
Comments
sorry i'm not used with
sorry i'm not used with blog, this comment was converted to a new blog entry
Re: sorry i'm not used with
Same bike as the rad2go sunbird I'm rebuilding I'm pretty sure. The hub motor on the rad2go is crap! If I can find ANYWHERE on this little bike to mount the motor I ordered, it will be chain drive. Does this bike have a tube frame? By that I mean the bottom is one bit 3" or so diameter tube steel?
hum...i'm not sure, and
hum...i'm not sure, and can't check right now cause the bike is at my parents house(the garage is better there :)).
But If I remember well...when I dismantled the bike, all the wires were tie wrapped on a big tube on the center of the bike.
When I will go work on this again I 'll check. I will have to get all the wires back there :)
Re: hum...i'm not sure, and
Sorry for the wait !
I almost forgot you !
here is a picture of under the bike
