Code: EO 152 countdown 4 hours?
7 posts / 0 new
jmap
jmap's picture
A friend of mine is getting longer charge times since his charger was replaced. Anyone can tell me what does it mean the charge code "EO 152" countdown by 4 hours?eo152.jpg
undead
Re: Code: EO 152 countdown 4 hours?
Does he have the new firmware - this could be the 4 hours balancing charge they were talking about in the upgrade documents. This should apparently happen after every 8 hours of riding or so.
jmap
jmap's picture
He says that the firmware is the old, at least they told him that. Is there a way of verifying the firmware version?
undead
Yep.
with the iginition key in and on, turn the engine killswitch off and hold in the rear brake lever.
With the old firmware, the speedo sat at around 45 (for throttle calibration)and thats it.
With the new firmware, the left had LCD displays the battery temp sensor reading, and a 1:00 unless the programmable delay has been changed, along with the speedo reading.
PT-Volt
Hi.
I did what you said (see it here)
What do you think? I have a weird version of the firmware?
Thx undead.
Thx Jmap.
undead
Not wierd, just old, thats what mine did before the upgrade.
So I have no explaination of what the EO code means - I have not watched mine all the waythrough charging since the update.
jmap
jmap's picture
Mine never did this 4 hour countdown (at least I never noticed it)...
