I finaly found the headlamp's for the 3500 Li
strawhistle
:) Hi, for those of you who don't want to blow the dc-dc converter by replacing a bad headlamp bulb with a hs4 12v 35/35w bulb's ! overload on the converter !!
I found a supplyer on ebay for the hs4 12v 18/18w lamps waiting for an email address to give you . I will finish this when i find out who they realy are LaTeR
strawhistle
Re: I finaly found the headlamp's for the 3500 Li
Here is the what i got off ebay CHINESE ATV SCOOTER HEADLIGHT BULB H4 P43T 18W NEW 12V
:) :? ;) :D 8) it worked !! they're like 10 bucks a piece I don't ride at night much but Wisconsin says headlamp must be on at all times So ? LaTeR
rossasaurus
rossasaurus's picture
Last seen: 4 years 3 weeks ago
Ten Bucks?!
Prety good markup!
Iccarus
Iccarus's picture
strawistle, where in Wisconin. I just got a 3500li and I'm on the IL WI border near Great America. Maybe we can have electric scooter meet in the summer. I added a switch to my bike so I can turn the main lights off if I want.(they use alot of juice) I just run the small center one in the day if I'm in low traffic. Not sure if it's totaly legal.
strawhistle
:) hay iccarus I live in Eau Claire Wi. 90 miles from Minniapolis mn. and its -12 here now! If you mod the front light to a 16m 3w spot Led the Bears will think it is the headlamp and don't bother you (around here) and it adds to the headlamps at night LaTeR
Iccarus
Iccarus's picture
yeah my friend switched his out with an LED light bar, but I don't like the rectangular look up there. I agree that the lights should be switched with LED lights where practical. So -12 huh ok I'll meet ya half way. heh heh
