Battery life.... what to expect
7 posts / 0 new
tempustemper
I am trying to convince my wife to let me get a new scooter. I am wanting something a little bit larger than my Schwinn s-750. The problem I am running into is that the batteries in the schwinn started giving out at 9 months and completely died at 12 months.
So, the question here is, would a larger scooter have longer battery life, or is the culprit the stock batteries that schwinn put in their scooter?
dogman
dogman's picture
Re: Battery life.... what to expect
The real issue, asuming that you ride the scoot daily, is sla batteries. There are better ones out there, such as B&B that are longer lasting, but quite expensive. Possibly you should switch to a nicad pack, unless you are willing to go whole hog and get lifepo4. Lithium polymer is also an option, but don't charge it inside the house or garage.
Nicads or nimh is the simplest answer to your problem, very very reliable and no dealing with bms and balancing issues. Ebikes-ca has nice packs reasonably priced that will fit in the space of 2 sla's. They will last that much longer enough to cover the price compared to sla.
Lifepo4 is potentially the cheapest battery per ride, but personally, I have 8,000 miles to go to know if my money was well spent. So far so good. If you do go for lifepo4, be sure to buy from pingbattery.com There are some ebay sellers out there that use inferior round cells. They sell a lot cheaper, but many complaints have been made on other discussion sites.
Buy the new scoot if you want, but you may get more for your money by just buying better batteries for the one you have.
I agree with everything dogman says. Just wanted to let folks know that www.elitepowersolutions.com now sells a 20Ah cell which might make the economics a bit more palatable for some folks...
tempustemper
so, for a 24 volt schwinn scooter, what battery back would you suggest and i am going to assume i need a new charger as well.
dogman
dogman's picture
Asuming the scoot used 12 ah sla, the ebikes-ca 8ah nicad should fit in the case, and then you need the charger for it too. In lifepo4, ping has the best batteries, but they are too tall. You'd have to ask him if he can make a pack that would fit the space. Range may improve a bit with a nicad pack, but mainly lifespan would improve with nicads lasting a lot longer, and they don't care how far you discharge em, so you could ride till it stops. With sla's if you didn't stop pretty quick, it would wear em out even faster. Most low battery lights go on long after the damage is done.
tempustemper
We are moving in the right direction, for my wife to win the argument. I hate that! Anyway, so i can't exactly find a 24V 8ahm battery back on their site, but i haven't looked really hard either. The only question left is what is that going to do to my range, since range is tied in to you amps?
The 20ahm battery would be nice, but its too tall. current battery specs are 5.94" x 3.90" x 3.74"
thanks!
e-doggies
e-doggies's picture
If your battery box is about 14.5 inches long, could you lay (2) 12V 20Ah SLA's on their sides, end-to-end?
