currie throttle can't handle the volts
Submitted by WilliaM007 on Sat, 01/31/2009 - 18:45
Hey guys, My project scooter is a schwinn s-350, stock controller, stock diagnostic throttle from currie, and stock 24 volt motor, Got 3, 12v 12Ah batteries and I'm trying to run the thing at 36 volts but when I turn it on the lights on the throttle just blink and won't go anywyere, is there any way I can just bypass what seems to be that safety voltage level without buying a new throttle? thanks
- WilliaM007's blog
- fatherchuck53
- eric01
- Norberto
- sarim
- Edd
- OlaOst
Comments
Re: currie throttle can't handle the volts
William,
I PM'd you some time ago. Did you get your scooter running?
