Mini motion sensor (tilt sensor) to activate/deactivate a 12 volt system.
2 posts / 0 new
kawa
I'm needing a very small and inexpensive motion sensor(tilt sensor) . The sensor will be used to power on/off a 12v relay which activates a device as long as there is any slight movement. When idle the motion sensor cuts the power to the relay. The sensor will be used inside a closed container with a 14.4V battery pack that operates the relay and a small motor.
Many Thanks
Re: Mini motion sensor (tilt sensor) to activate/deactivate ...
Have you thought about using a mercury switch like they use in a house thermostat?
Grandpa Chas S.
