looking for Li-ion cells
10 posts / 0 new
autx790
Can anyone recommend some good li-ion cells (in the 5-10Ahr range) and also where I can buy them?
I am not looking for iron phosphate or lipo cells.
Peyton
Re: looking for Li-ion cells
A good place to start is to look at our EV Collaborative Handbooks under EV Batteries. There is a large amount of data on VisforVoltage which has been compiled and placed in the Handbooks to help answer questions that have been asked over and over.
hope this helps,
Grandpa Chas S.
autx790
Ok, Thanks! I'll check that out.
Sorry, I probably should have done some searching on here before posting.
I have reviewed that section of this forum, but did not see any information regarding what I am looking for. I have seen where SAFT makes the cells I am looking for, but I am still waiting to hear back from them so I'm looking for an alternative. I'm looking to make a 48V 60Ahr battery so i'm wanting to stay away from 18650s but can't find any other options online. Any suggestions??
There is a seller on ebay know as ping. Many of us have purchased packs from ping with very good results. His packs do not use the 18650 cells. His prices are very reasonable too.
Grandpa Chas S.
autx790
Thanks for the feedback, I have seen these packs before, and it's good to know (for future needs) that they are reputable. However he uses the iron phospate cells and I am trying to avoid using these.
I am also working on developing my own battery management system so I'm looking to make my own battery. I could disassemble a premade pack, but I'd rather a different chemistry than FePO4 and one not rapped in duct tape.
For other reasons, I don't think I can order my cells from ebay, or from china, which makes this a bigger pain.
Cruisin
I can help you with your interest in Lith Ion battery's at a resonable price. Info is available at cruisin [at] live.com.
AndyH
Peyton
Peyton - what chemistry do you want to use? Lithium ion is a generic name for a range of cell chemistry. You've ruled out two of them - lithium iron phosphate (LiFePO4) and lithium cobalt (LiPo).
Are you looking specifically for lithium manganese? (edit: I see you mentioned Saft - they make a full range of cells so that doesn't narrow it down... /edit)
What's your goal for the pack?
Andy
autx790
Andy,
Sorry, I do not have much knowledge on the chemistry, I still have a lot to learn.
My goal is to make a smaller and lighter weight battery to replace a SLA battery back-up for a solar panel. My main focus is on the BMS i'm developing, but the application is for a solar backup to power a 30W Wi-Fi radio which takes a DC input from 40-72V, so it's not a high power application. However, I do need high capacity.
Saft appears to have blown me off, but I hear they are quite expenisve anyway. It seems the lightest, cheapest and smallest form-factor option is to go with 18650 cells and just put about 15-20 of them in parallel. I'm not sure how much of a headache that is going to be, but I was hoping to avoid it. I ordered a Tynergy LiPo cell as well, and will see how reliable it is. I may go that route as well.
Peyton
AndyH
Thanks Peyton - that helps me understand. I still don't understand ruling out LiPo or LiFePO4. ;)
If I wanted to replace lead in a fixed application - like an electric gate or your radio installation, I'd use LiFePo4 hands down. They have the easiest management, lowest 'hazard' potential, and longest cycle life of other lithium commonly available. If longest life/best value is the primary factor, LiFePO4 wins. If absolute smallest package and lightest weight is far and away the main factor, than LiPo wins.
Here's a pretty decent LiPo pro/con thread that might help: http://www.endless-sphere.com/forums/viewtopic.php?f=14&t=9170
I still think LiFePO4 would be a better choice. Charging can be done inexpensively, and can be done by a lead-acid charger/charge controller commonly used with solar. You can get smaller cells, sure, but can also get 10Ah 40138 cells, and a range of packs from Ping and Cammy_cc on ebay in 10 and 20Ah. Any LiFePO4 solution is going to weigh 1/2 of lead. If you keep fairly shallow discharges (40-50%) you can expect more than 2000 charge cycles. 40138 cells tested by a US lab provided more than 8000 cycles in the hybrid car routine - where the cell is never charged above 80% or discharged below 40%. Even at regular 100% discharges, you can expect at least 1500 cycles before capacity drops to 80% of new. This is compared to lead's 300-500, and LiMn's 500 cycles.
How many days of bad weather do you need to pack to provide? What's the current draw of the radio?
Keep us updated with your project!
Andy
Andy,
Peyton
autx790
Thanks for the response. I'll look into some LiFePO4 cells, but I didn't give much attention to them since they appeared to be heavier and more ideal for high power applications. I used a123 cells in the past but that was for an application that needed the power density. One of my main focuses is size and weight, and it is a lower power application. Ideally I would have gone with this Quallion cell, but they had a long lead time.
http://www.quallion.com/sub-sp-ql0045a.asp
I'm looking to size the battery to be able to provide at least 3 days of backup power but will probably reconfigure along the way. I haven't done much with solar so I'm not really sure what to expect...doesn't seem to promising so far, but there are some good advances coming out in that industry. The radio will draw between 0.75A and 1A depending on the battery voltage. It requires 40-72V input.
I ordered some Samsung 18650 cells as well as some tynergy ones, and also a LiPo cell. I'll see how they go.
Thanks again,
Peyton
