What is the maximum Real World Mileage on one Vectrix Battery so far?
2 posts / 0 new
How well are these batteries holding up so far?
What is the maximum distance anyone has traveled on their Vectrix using the same battery?
For the purposes of making it comparable, we should probably count the 2008 battery recall as a battery replacement, unless proven otherwise. Someone might have observed the battery "rework" being done by a traveling Vectrix technician, but as far as I can see most scooters were sent back to the workshop. Most likely a new battery was put into the scooter. They might have reworked the battery in the workshop, but it is not likely because it is a lot of work with the potential for many errors, if not done properly.
turok
turok's picture
Re: What is the maximum Real World Mileage on one Vectrix ...
To me, it also seems interesting to know the other value: minimum range, and how you did it.
I'll be adding my numbers as soon as possible.
(I'm not backing out of my purchase because of the rumours, I'm confident, even in a worst case scenario!)
