XM-3000 what is the max volts u can run on it?
2 posts / 0 new
mrladderman
mrladderman's picture
i have a added 1 battery to my xm-3000. so its at 72 volts now. could i add any more volts to this system with out hurting the controller.?
Iccarus
Iccarus's picture
Last seen: 8 years 4 weeks ago
Re: XM-3000 what is the max volts u can run on it?
I don't know if it's the same controller as the 3500 but I'm running mine at 96v (full charge) that's about 84v nominal. Now I don't know how long it's going to last but so far so good.
Bill- 3637 km on 3500li 28 cells
