Whats best hub motor or the type use in the Cheetah homebuilt?
2 posts / 0 new
Badger
what works best and what is cheapest for a no pedal scoot/Moped?
Last seen: 9 months 1 week ago
Re: Whats best hub motor or the type use in the Cheetah ...
In the book he makes it clear the motor choice is based on your needs. If you need huge power but buy the cheapest motor it will keep you from a motor like the ETEK or MARS. But if you go with a high power motor it needs to be matched with hefty wheels and brakes.
