Is there any model/chassis with this specifications?
10 posts / 0 new
RuFuS
RuFuS's picture
Hi guys!
I'm searching for a long time a motorcycle like this:
With better specifications...can anyone help me?
I would like to have this model with something like this:
Batteries: 20x60Ah (or better)
Motor: 5kw (or better)
Which of course would give...more speed and more range...
I need at least 45mph (70kmh) and 35miles of rang at maximum speed...which is perfectly possible with the specs above...
Can someone tell me if this exists and if so, the contact of some european distributor or even the main manufactor? (which would be in china of course)
Thanks in advance!
Regards
Re: Is there any model/chassis with this specifications?
dont think you can buy one with those specifications already,
however you can buy an Emax classic (it has that body style)
then install a different battrey pack and a new controller (the stock motor can handle 45mph no worries).
only real problem is fitting 20x 60AH cells in that body style.
RuFuS
RuFuS's picture
But I think there is a model with 5000W and 60v/40Ah battery pack...can someone please check this?
Because I searched a lot and i can't find it...
Regards
You can get 5000w scooters.....just not in that body style (as far as i know...)
stock 5000w scooters are built on maxi scooter chasis, partly because the handling on the smaller scooter frames at 50+mph is a tad dicey
Mountain chen
This is our Beauty model in www.erider.cn
This model don't have enough battery room,unless put battery in storage tunk !
RuFuS
RuFuS's picture
Yes, it is...
But i would like to see a better motor (and controller also) in that chassi...20x40Ah it's enough, but the motor probably it's too weak for that amount of cells...
Mountain chen
Yes, it is...
yes,13" wheel motor new model could be 24 cell 40AH or 20cell 60AH LFP battery72V battery.JPG
RuFuS
RuFuS's picture
Yes, it is...
Are you sure that this photo belongs to the beauty structure???
It seems to me that it is the thunder model...
Mountain chen
Yes,this chassis is Thunder new model,
Beauty don't have enough battery room and motor size !
justincbi
We have. Contact me at justin.cbi [at] gmail.com. I will send you spec. sheet.
