Comparing Larger Retro Styled Scooters 2009
boyelectric
Comparing those retro styled large scooters again!
Here's how some newer models are stacking up for specs:
Name Watts Volts AHr Chemistry Max Speed Range Weight Load Brakes Price
EVT-168 1500 48 30 LiPoly 30 45 198 ? disc/drum $4199
E-Moto Retro 1500 48 20 Silicon 28* 10-12 253 ? disc/drum $2195
E-Moto Classic 2000 48 20 Silicon 28* 30-35 308 ? disc/disc $3095
e-Cruiser 220 2200 60 40 silicon/lithium* 42 20-40 240 400 disc/drum $2995
eSoho 3000li 3000 60 55 liPoly 45 45 350 400 disc, antilock $4000
R-30 3000 60 35 lead 45 30-45 321 319 disc $4000
Zapino 3000 60 38 lead 30 30 297 280 disc/disc $3495
ES3000li 3000 60 40 liFePO4 42 60 ? 440 disc/disc $3790
XM-3100 3000 60 38 lithium 40-50 50-85 306 282 disc/disc $2500
Re: Comparing Larger Retro Styled Scooters 2009
I think the XM-3100 has Silicon batteries not lithium (as confirmed by Mountain Chen on a different thread).
Current Motor Company is evaluating our options for an entry into this category. Would be LiFePO4 40Ah / 60V with a BMS (I doubt any of those bikes listed have a BMS). Price likely around $3500 to $4000. Probably won't be out until end of 2009 or beginning of 2010.
boyelectric
Yeah, I saw that in another thread. X-treme keeps insisting they are lithium, so not sure who to believe. At that price it does seem to be a good deal. I am just wary of their controllers, chargers, and the lack of BMS.
boyelectric
Looks like my estimate for the ES3000 is off a bit. They are selling the bike for $2495 + $900 for the LiFePO4 upgrade... $3395 total. They have a BMS coming out in the fall, and right now they do offer a 'balancing charger' for about $400. Their controller is the same as the Zapino.
Still, I do like the LiFePO4 batteries at this price.
Thoughts?
Looks like there are two places selling the ES3000 - one at $4500 for the Li and the other that you list above at $3395
Things you might want to check:
(1) how many cells? Some supply 19 cells, some 20.
(2) what exactly does the balancing charger do? If there aren't 19 (or 20) per-cell connections then it's not really able to do much good
(3) who makes the cells? what is the warranty? how to claim on the warranty? can individual replacement cells be purchased?
Good luck - and if you go ahead then be sure to let us know how it goes.
boyelectric
Yeah, I talked to them about the balancing charger; I think they would agree with you. They say that is why they are hoping to release a true BMS in fall. Time will tell if that holds true.
