charging glitch?
2 posts / 0 new
turok
turok's picture
charging glitch?
I plugged in my V yesterdag night around 23.30.
This morning, around 8, it was still "charging" in EO mode, with the timer at 2:16 and counting down.
So I assumed, it was in equalization mode (as mentioned in the manual, done every 100 hours of use or so?).
But half an hour later, I went back, the process was interrupted, the system was restarting over and over again. (starts charging, cuts off, and restarts....)
I've seen this once before, unplugging it resolves it apparently.
I'm not worried, although stuff like that might overcharge / damage the batteries I guess.
Otherwise, my v is behaving perfectly (1550KM so far, no serious probs).
anyone else seen this kind of behaviour?
turok
mikemitbike
mikemitbike's picture
Last seen: 12 years 3 weeks ago
Re: charging glitch?
Hi Turok,
i´ve seen this on my Vectrix during its first equalization charge with the new software on it. It startet several times in the CP mode
reaching 152v switching to trigger with turnd off display and restarting to CP mode. The battery stayed rather cool in this phase.
Greetings Mike
