Someone Donated the Junk Scooter to Deafscooter
Deafscooter
Deafscooter's picture
Last seen: 18 years 10 months ago
Craig got the three useless scooter from someone ( who want donated all scooter to Deafscooter )
The Red or Black Frame will going Build off for WRAD Deaf Bike ride on Beach side in Aug 11, 2007
The Blue Frame will going Electric Scooter Racing Tracks or Route 66 Rally on AMMRA or USSRL
Deafscooter have new design to Build off the "Junk Scooter" in good Relife scooter to use again .....
Here is Picture on Donated from someone who want rid the junk thing to Deafscooter for mods ..
Re: Someone Donated the Junk Scooter to Deafscooter
Deafscooter,
If anyone can put life back into these scooters you are the one to do it. I hope you will post how you are making the changes so we can all learn from the master scooter builder. We need lots of pictures too.
Chas S.
My Bicycle Pages
amp_head
amp_head's picture
I can't wait to see what you build out of all those old parts!
Make sure you take some pictures. You remind me of Monster Garage. :)
Deafscooter
Deafscooter is Here...
I took Red Frame to design the Framework for Long Range Ride on beachside biking path
Draw over the Frame to add on metal frame to strudy the frame and add on heavy battery
and add on motor mount and speed controlller aslo lower seat level and hand bar will be fit
Craig doing metal work chopping and wide frame for large battery then build off the battery tray
and add on metalwork to frame job to fit the battery and motor also speed control will on rear
of scooter frame and add on strong seat post support and chopped T-Steering bar to reduce
the wheel will be replacment with strong wheel with 12 mm dia axle and custom made sprocket
Craig Uyeda
Deafscooter
here is Picutre on before on Modified the frame work with four large battery packs
here is Pre Frame work ( overlaying the image with add on pipe work and metal on it
deafscooter
Deafscooter
Deafscooter doing build off on Schwinn ( move to new topic )
Move to new Topic Deafscooter Build off the Red Schwinn s180 Frame to "Long Range Ride"
Check on ==>> http://visforvoltage.org/forum/small-scooters-and-pocket-bikes/1396
Thank you for View here .....
deafscooter
