How to adjust Zapino's rear suspension
3 posts / 0 new
__Tango
Hey folks.
I was wondering if anyone has any info about adjusting the rear suspension on my zapino. I bottomed mine out today going over a pothole :-(
It looks like it's a simple twist mechanism, but i've never worked on anything like this before, so was wondering if i need any special tools or equipment.
...alex...
justincbi
Re: How to adjust Zapino's rear suspension
There should be a ring with something like teeth which allow you to turn on the end close to the rear axis. You just turn it loose or tight.
__Tango
Thanks. I found a tool that worked (someone told me to use a plumbers tool that's used to work on garbage disposals), and was able to turn the ring.
