Vectrix mistery 2: The random voltage
Last seen: 4 months 2 weeks ago
During the Equilization phase I accidentaly pulled the left brake lever, with the kill switch off.
The voltage display immediately became mad and started to display different random numbers, very quickly. Releasing the lever enabled the voltage again. The secuence of mad numbers started immediately after pulling again the brake!
I have a pair of questions:
Does anybody know what are this ramdom numbers for?
Anybody experienced this issue? Anybody can reproduce this same behaviour?
Here som pictures of the random nunbers.
They randomed between 0 and 250, aprox.
They changed so quickly that it was very easy to take a shot of numbers changing.
Here some pictures of the numbers:
X Vectrix
Re: Vectrix mistery 2: The random voltage
SW bug.
SW bug.
thanx
Probably you're right, it can be a software bug, like the bluetooth issue. But i'm interested in finding out if my bike is the only one in the world that experiences this isues or on the contrary, there are other Vectrix that behave like mine... If my software is corrupted, I'll look for a replacement update. On the other hand, if it is a general issue of the SW, there's no point in updating the system.
X Vectrix
No, it IS a SW bug. All bikes will do it randomly.
clagros
The same happened to me a month ago, after interrupting a charging cycle.
Each time I pressed the left brake lever I got a different voltage numbers (if I'm not wrong from 81 to about 200).
The VX worked normally and it never happen again...
