MY1020 question
2 posts / 0 new
AppTarheel
Last seen: 16 years 2 days ago
MY1020 question
Does anyone know if the drive sprocket can be removed/replaced from MY1020 motors easily? I'd like to know before I buy it and the seller hasn't answered my questions about it. I'm replacing the existing sprocket with one that will fit a bigger chain.
thanks
captainslug
captainslug's picture
Re: MY1020 question
They are dual-d-bore sprockets held on with a hex nut and lock washer. Depending on the derivative model you get, the size of the dual-d-bore will vary.
To change the sprocket you basically have to machine and weld one onto the sprocket that came with the motor.
