Regenerative brake
4 posts / 0 new
cferron
Regenerative brake
Is this a normal behaviour?
When I brake the generative break kicks in but no bars appear on the console until I reach a speed of about 14 km/h. It is only at that speed then you see the "G" bar until I come to a stop. As opposed to the G -4 Mode, even if I roll at a 30km/h speed and the mode kicks in, I see the bars on the console (from 30 to 0 km/h)
Normal?
Claude
pondopholous
Re: Regenerative brake
I get one or two bars even when braking from a walking speed down to almost a stop. Mind you, I've boosted the regen braking effort setting to about 60 or so. If I remember correctly, the default brake effort setting is quite low.
cferron
Low speed is not the issue in my case, I get almost ALL bars. When I brake at 32 or so I don't see any bars until I reach the 16km/h or so speed... My brake assist setting is setup to max power.
Claude
Dennis
Dennis's picture
When the regen is set to max, I hope everyone is checking their axle nuts before each ride.
a couple of helpful vids from FalconEV...
