e -max 110s electric scooter
kevin smith's picture
hi guyes does any body no how to un restrict emax scooter 2008 model
as it is electronically restricted to 30 mph but i am sure that i had seen a french site how to do this ??
but it was a wile ago my son is borrowing at the mo and says its too slow so would like to proove to him its better already than the old broken ic engine in the back am trying to fix at the mo but he may keep it if i manage to un restrict it to a resnoble 35 mph as i fitted a new brain to it as
they had a recall and fitted new brean and will hit 30 but slow to get there but now seems to like 28 a a a tad slow sidev but al in all style 10/10 range 60 miles acheved 8/10 as not lithion old style silicon thanks kev hope some one can shed some light on it
Comments
i hadnt realised the 110s was so slow
in theory, there is a jumper connector inside the controller (controller will have to be dismantled, voiding your warranty) that can be removed which de-restricts the controller.
if the resulting new top speed isnt high enough, then you will have to raise the battery pack voltage aswell.
Note: any increase in average speed results in a dis-proportionate increase in power requirement. your range will be reduced at a higher speed. at 35mph, your range will be around 37 miles (if you want your batteries to have a good service life, then less than 30 miles).
in a few weeks ill have a 110s of my own to play with, so i can tell you more then.
note for future reference - when something fails on any EV you own, never replace with a stock item. there are always better parts available with far more documentation.
nice on matt keep in touch
al just sit on that at the mo as son not given me any grefe for few weeks and so happy at saving
money as he not paying owt out as he is charging at hi moms .chears kev
Hi!
You are right, it is far too slow! I tested it a few days ago. Do you have any more information about the "new" controller yet?
I understand that the new e-max controllers are firmware based - so the computer program would need amending to change the limit speed or remove it to allow top speed based on voltage. I have asked e-max themselves about how this can be done and I'm waiting for a reply. I'll post something here if and when I hear from them.
I have one of the control boxes that allows to change the following settings:
max output frequency (this is the setting that controls max motor speed, standard is 168Hz or 45kmh)
max battery current (standard is 45A, max setting is 80A)
max boost battery current (standard is 60A, max setting is 80A)
and a few other things that i cant remember (or rather wasnt so interested in)
problem is, the control box is different for every firmware revision.
So one programmed for one revision, is useless for the next (actually quite bad if used)
110srider - having a look at your controller, i suspect its from production date earlier than march this year.
All scooters after march this year have brown 80v ripple caps. the ones before have the 63v variants.
The reason the emax parent company dont sell the control box (to end users or even dealers) is due to warranty and liability issues.
in some countries going faster than 45kmh has serious consequences (for the manufacturer), particularly if you then crash and the cause of accident is determined to be excessive speed.
de-restriction of the scooter also voids warranty.
On the scooter i have de-restricted, the hall sensors in the motor failed.
I still trying to determine if this is a co-incidence or not.
It is possible the higher than rated frequency has caused failure (the motor in all current models has more poles than in the original emax, meaning a higher operating frequency).
aidanworthington's picture
Hello im new here
iv just purchast an emax 110s myself it is a good bit of kit but there is a few things wrong with it mainly lights staying on. anyway after a bit of thort its going for a makeover using a normal scooter wiring loom(with no gray boxes)new frount wheel with speedo drive new set of bars and so on . The thing is would a kelly 200amp 48v controler work with the emax hub any ideas.Allso do u know any good web sites for a 48v to 12v dc to dc converter im thinking about 150watt any help would be aprecated
not good at this spelling thing lol
LIVE LONG AND PROSPER
a kelly controller would work fine, especially since you have already done most of the necessary re-wiring to make the other components work properly without the original controller.
the controller you have specified would work, however, if you are after more speed as well, go for a higher voltage unit.
The emax hub motor is a standard BLDC.
kelly controllers also sell dc-dc.
thanks for the info mat cheers
  • Iber
  • AndresV10
