home brew electric outboard
7 posts / 0 new
Webmaster
Webmaster's picture
Last seen: 2 months 3 weeks ago
Here's an interesting website I came across regarding a home brew electric outboard. Very good pics and info.
http://www.psnw.com/~jmrudholm/etekoutboard.html
Gushar
sam_uk
Re: home brew electric outboard
Hi all
I am looking to build a low cost electric outboard for a 21 ft displacement sailboat.
I already own 1000ah of lead acid and a 1kw wind turbine so I am keen to stick to 24v.
I Have read the link above and this one http://www.sailnut.com/projects/eska_electra/
In the Sailnut article he uses a 1000w motor.
I have found these 1000w 36v motors on ebay http://cgi.ebay.co.uk/Electric-Scooter-36-volt-1000-watt-MOTOR-Electricscoote_W0QQitemZ190358214494QQcmdZViewItemQQptZUK_Sportin...
I also found a controller http://cgi.ebay.com/ebaymotors/Electric-E-Scooter-24v-1000w-Controller-Throttle-Kit_W0QQcmdZViewItemQQhashZitem27ac62b3aaQQitemZ...
However if I was to run it at 24 volts how would this effect the rpm? Is running such a motor at a lower than rated voltage a very inefficient thing to do?
Can I expect to get enough torque from a motor like that?
Sam
Yes lower volts will give lower RPM so far as I know.
It might work okay and one way to tell is to do as my dungeon master used to say: Try it and find out
I suspect though the motor you're suggesting is underpowered for the application.
Fourcycle
Fourcycle's picture
Last seen: 10 months 4 weeks ago
The odd thing about that 36 volt, 20.6 Amp, 1KW motor is that 36 volts times 20.6 amps yields 742 watts. I wish they made 134% efficient motors! I'd have my personal perpetual motion machine running in no time! ;o)
My in-laws just replaced the stinking 9.9HP Johnson in their 27' Bristol with a 9 HP 4-stroke and 2000 to 2500 RPM motors them along very nicely. A rough guess would be around 4 to 5 HP for them. For your 21' displacement hull, I'd think 3 HP max would be a good number to shoot for, which works out to be about 2.2KW. If the motor is ~80% efficient, you'd want about 2.75KW of electrical power going to the motor. At 24 volts that works out to be about 115 amps going to the motor. Instead of a 36 volt motor, I'd be looking for a 12 to 20 volt motor that can handle that kind of current. How the motor is wound has to do with how much power it puts out at a given voltage. For an inboard installation, you may want to consider adapting a powerful bicycle or scooter type hub motor. Being low RPM motors you could make it direct drive to the prop, avoiding the typical 2-1 reduction found on many EV inboard installations.
If your only tool is a hammer
everything looks like a nail.
sam_uk
Thanks for the responses..
Looking at the real life figures for the etek outboard;
http://www.psnw.com/~jmrudholm/etekoutboard5.html
It seems that at lower speed, even though the motor is massive, the amp draw is not _that_ much higher than a much smaller motor eg; http://electric-outboard-motors.co.uk/minn-kota-riptide.htm
I am therefore thinking it might be good to get a oversize motor and under-power it in normal operation. This would also give a 'get me out of trouble now' safety margin.
So I am now thinking of one of these
http://visforvoltage.org/forum/4054-holy-smokes-7000-watt-brushless-motor-controller-recommendations
With this controller KEB48300
http://www.kellycontroller.com/mot/Ebike-BLDC-controller.html
It seems that a higher RPM would be desirable "the old Johnson motor was rated for 4,000 - 4,500 rpm" http://www.psnw.com/~jmrudholm/etekoutboard2.html
The 7kw motor "So if you're running it at 24V, then the max RPM is 4320 which is usable." seems about right http://visforvoltage.org/forum/4054-holy-smokes-7000-watt-brushless-motor-controller-recommendations#comment-23240
Does this seem like a good way to go?
Sam
sam_uk
on the other thread about these motors there were fears about their longevity. Have many of them burned out? or do they seem worth the money?
Sam
Reid250
Sam;
On this site, you will find many of your countrymen "Bin der, dun dat".
http://groups.yahoo.com/group/electricboats/?yguid=206608459
Go and read the archives for a week or so and then ask questions.
If you want to see guys who have been racing EV OUTBOARDS SINCE 1992 and now have the ultimate EV outboards, look here:
http://www.seattleoutboard.org/electric.html
Google is a marvelous resource to learn to use. The world is at your finger tips. It was my interest in large EV boats that facilitated my stumbling onto Scoots and now I have one.
