Extreme XB700LI
17 posts / 0 new
nutnsez
Extreme XB700LI
I am trying to figure out why my father-in-law's Extreme XB700LI has such poor steering in a turn. I think it is because the rake and the wheel diameter are both too small. My father-in-law is wondering if he could have done something incorrectly when he assembled the front end. I would appreciate any thoughts.
By the way, I am having a very difficult time trying to figure out how this forum works. Hopefully I posted correctly and will be able to find your responses!
mf70
Re: Extreme XB700LI
At least when I unpacked my XB-600, the only thing to attach was the wheel:
http://visforvoltage.org/forum/6832-new-xb-600
Now, if the spacers didn't go on right, the wheel might not be centered...
http://visforvoltage.org/forum/6876-xb-600-front-axle-spacers-question
You could check the geometry of the steering tube. The axis of the steering tube should about touch the ground at the contact patch of the tire on the ground. If it is AT ALL to the side, handling will be terrible.
nutnsez
Re: Extreme XB700LI
Thanks for the advice. It sounds like good things to check. Will do!
mf70
Re: Extreme XB700LI
Looking at this photo, it looks like the fork lugs could get turned 180 deg, 'till they were behind the shock tube. That would screw up the handling effectively.
//i200.photobucket.com/albums/aa122/mf70/XB-600/P6190095.jpg)
The wheel lugs need to be ahead of the fork struts.
nutnsez
Re: Extreme XB700LI
Thanks. I appreciate the advice I have received so far but I still haven't found a reason for the unstable handling. Any other thoughts?
JamesS
JamesS's picture
Last seen: 13 years 4 days ago
Re: Extreme XB700LI
Nutnsez,
It would be harder to assemble the front fork/wheel incorrectly, fender mounts and reflectors basically dictate the orientation. When you say it is unstable, I have a hard time trying to understand your complaint. Is it under steer? Try riding with the pedals on so your feet are more spread out and see if you feel more comfortable in turns.
Happy scooting,
JamesS
nutnsez
Re: Extreme XB700LI
Hey James!
I don't know what "under steer" means. It's handling reminds me of riding those push scooter with wheels the size of skateboard wheels. The steering head feels like it wants to go faster than the wheel. Then the wheel kind of stalls while the handlebars start falling inwards. Like I said, this is my father-in-laws scooter and I have only ridden it once. I hope to get back to his home soon and do a more in-depth check and evaluation. He does not have the pedals on. That sounds like it would make it more controllable. Thanks for the suggestion.
JamesS
JamesS's picture
Re: Extreme XB700LI
Nutnsez,
Well riding a scooter you basically sit atop it and don't get the more secure feeling you might get from a motorcycle. You can't wrap your legs around it. That is why I suggested the pedals as a point of balance. Sitting atop a scooter makes you feel like you can't lean as much, but you really can. It feels strange, but try it.
We grew up on bikes and perhaps motorcycles where our legs are down beside us. not in front of us. It throws our balance off.
I have yet to slide or not make a turn, but I know the feeling of wondering if I was going to make the turn. I always do, so ride it like you stool it and you will corner like a racer. Best of luck.
Happy scooting,
JamesS
nutnsez
Re: Extreme XB700LI
I ride a motorcycle and can therefore totally understand what you mean about a scooter seating position being less "secure". There's probably nothing I can do about that. Even understanding that I still have concerns about this scooter. My father-in-law told me that some people from an electric scooter group rode it and also found it to be less stable than they expected it to be. I appreciate your input. Thanks!
sixpax2k9
Re: Extreme XB700LI
I have noticed on some x-treme bikes, including my own, the front fork is not as "tight" on some as it is on others. I believe it is the shocks may not be as tight as some of the others, thus allowing a lot more play than on others. The only way to change or fix that is by a front fork replacement. The reason I feel this way is this... on my xb600, assuming the 700i is the same, the shocks have no stabilizer bar between them. Only at the fork above them, this allows the individual shocks to twist due to the fact that the only thing that is keeping them straight are the nuts and bolts going through the front axle. If there is a spacer or washer or any locking nut missing that can multiply any handling effect.
My best advice is to re-inspect the front axle check for missing spacers or washers, install locking washers if none are present. And keep them as tight as possible. I do not believe you can tighten the shocks without major modifications. I am however fairly certain this is the reason that some bikes are not as "stable" as others....
Dave ; Tennessee
XB-600.
sixpax2k9
Re: Extreme XB700LI
As a matter of fact... the above picture of the front fork pretty much proves my theory.....
If they are free to twist and rotate prior to assembly, what is to stop any play after 1 bolt and some spacers, washers, and nuts are inserted?
If there was a way to have a stabalizer bar between the bottom half of the shocks I am sure it would solve the issue. I guess some shocks allow less movement than others due to the way they are made. IE the way the washers etc. are packed at the movement points and how tight any rubber washers and gaskets etc. are.
Anything you can do to make sure the front shocks are as completely parallel as possible and as secure as possible will help a lot. If they are even a little off, it will allow for a lot of play. Adding or removing spacers and or washers between the forks should do the trick....
Perhaps some kind of a rigid metal U-shaped bar attached above the front mud guard into the same screw holes would help?!?!?!?!?
Dave ; Tennessee
XB-600.
mf70
Re: Extreme XB700LI
That brings up another element of the steering geometry; the head tube bearings need to be perfectly adjusted. If they have any looseness, you can have a really wild ride. I've laid my XB-600 down because of this.
As I see it, the problem is either the forks being assembled with the axle lug behind the axis of the shock tubes, or the headset bearings are loose. (It also may be that the shock clamps are loose, but that is much less likely.)
Can you post a photo of the axle/shock connection?
Mark
nutnsez
Re: Extreme XB700LI
No can do. Right now it's snowing at my Father-in-Law's (Frank's) home, so I can't even get up there to check it out myself. I have been passing along what has been shared to Frank and he's been following through. I too wondered if the headset bearing are loose.
JamesS
JamesS's picture
Re: Extreme XB700LI
It would be almost impossible to have the shocks 180 degrees, placing the wheel lugs to the rear of the shock. The reflectors would be on the inside and the fender mounts would be to the outside.
See http://visforvoltage.org/forum/6951-basic-maintenance for more on gooseneck bearings
Happy scooting,
JamesS
Deputydaves
Deputydaves's picture
Re: Extreme XB700LI
Let me throw in a suggestion, I ride and work in pedal bikes extensively and we there is a similar problem in cycling. It happens when the front wheel and the Back wheel aren't on the same line. They may be parallel but not on line. Assuming the frame is as straight as possible, take a measuring device and make sure there's equal spaces from the tire to the frame on both sides. Then do the same to the fork and front wheel. It's an easy fix and makes a world of differance. Many people can't believe what a differance in handling this makes.
Hope this helps.
Dave S.
Dave C. Stout
STOUT PRODUCTIONS
Low Carbon Products
nutnsez
Re: Extreme XB700LI
I finally got out to my Father-in-law's to check out his XB700LI while armed with all of your comments. The front axle bolt and the bolt holding the handlebars to the front end were both seriously loose. However, the thing that made the biggest difference (I think) was low air pressure. It is now waaaaaaay better. Thanks to all of you who shared your thoughts and experiences!
mf70
Re: Extreme XB700LI
Thanks for posting in the first place. Steering and wheel maintenance and inspection is a crucial element in safety for these scoots, particularly with the far back CG with the normal American rider. For those that are juicing your ride to 50% higher voltage, please read this!
