THROTTLE Control Flopping around on X-Treme Li3500W
2 posts / 0 new
Reid250
Not quite to 100 miles since new and the throttle control is flopping. I can't see any set screw and I can't get the end cap off without the probability of destroying the control? What normally holds the control tight to the handlebar? Is it normally tight to the light switch or is there a 3/4" gap?
Any and all ideas welcome.
Reid
Reid250
Re: THROTTLE Control Flopping around on X-Treme Li3500W
I found the solution. A tiny Allen head set screw just above the I-O switch. There is a large soft plastic sleeve on the steel handlebar which the screw bites into. One tiny set-screw is all that is stopping the throttle housing from rotating. MM. It needs several larger set-screws to be effective.
