PC controlled motor as a variable load ?
2 posts / 0 new
max2tall
I was hoping someone could help out with some thoughts on EV type motors & controllers in a stationary PC controlled situation.
The need is to control and monitor rpm and negative torque where the driving is provided not by the motor...
So how to best use a motor as a variable load ?
Is this easily implemented with any of the motors & controllers popular here? About 20Nm max & <1000rpm intermitent would be good :)
Would the Crystalyte 500 type motor be a good choice for this? Is there any PC supported motor controller that I can use to achieve these goals ?
Cheers & thanks in advance for any assistance out there !
max2tall
Re: PC controlled motor as a variable load ?
anybody ?
