WE Stopped working
7 posts / 0 new
blairg
blairg's picture
WE Stopped working
My We brushless motor stopped working today. The lights on the controller have a steady red light and blinking green light. The throttle indicates full charge. My multimeter reads over 36 volts on the three prong connection from controller to wheel. Any suggestions ?
silentguy
Re: WE Stopped working
Did you get your problem fixed ?
I have the same issue with the blinking green light on my controller.
I get some power to the motor, but it is not drawing much Amps, and only spins at about 8mph.
The motor vibrates a lot, and is noisy.
It may be time for a new controller ?
blairg
blairg's picture
It's happened again !! Replaced controller and it worked for about 8 months and has happened again !
blairg
blairg's picture
Where can I get a new controller ?
proton
proton's picture
For a differant controller - I have one, $150
36v, 40A
blairg
blairg's picture
It was a loose connection...all ok. PHEW !
JLGRAU
It's nice you you figured out problem. Typically, the battery wiring can come loose. Other wires can also be pinched/bent thereby leading to poor contact. If you didn't overvolt or overwork your controller, it's likely a contact problem. That's my experience on brushless and brushed motors. But I previously cut the wiring near the hub axle. This can cause all sorts of problems.
