Gelato Electric Bicycle Need help please?
Mr.Gelato's picture
Hi I just got a gelato electric bicycle for 50 dollars. It runs good but it has some minor problems. One problem is that it doesnt pass 10mph when its suppose to hit 20mph. Second problem is that the battery gauge dont work. Does anyone know whats wrong with the bicycle and how I can fix it? Thanks!
Comments
From what I have read, your bicycle is a 48 volt vehicle, and should have 4 identical 12 volt batteries, and at full charge, the total voltage should be about 55 volts D.C. (each battery should read about 13 to 14 volts) It is very likely that you need a new set of batteries, that is probably why the previous owner sold it so cheaply! Get new batteries, and performance and the battery guage should be correct, but TEST them with a digital voltmeter first!--Bob
