Tilting Electric Tricycle
3 posts / 0 new
ecoway
What's the biggest problem with normal trikes? Getting around corners! New Electric Tilting Trike, using patented tilt technology! When you lean or any sudden change of direction is made, the front section of the bike tilts but the rear wheels remain on the ground flat and stable! At just 30Kg the trike is very lightweight for a trike using a compact Lithium battery pack located below the large rear basket.
Tyre: front 20" x 2.15 + rear 16" x 2.15
Battery: 36V/10Ah Lithium-ion battery
Motor: 250W BLDC
Brake: Front V-type brake + Shimano rear roller brake system
Control system: electronic regulating system
Max.Load Capacity: 120kg
Net weight: 30kg
Range Per Charge: about >45km
Climb gradient: about 6 degree
Charger: smart charger
Max.Speed: 25km/h
Transmission type: axle and double chain transmission
Drive system: front wheel drive (Pedal Assisted System+Throttle)
Light: head light with meter + tail light
Brake lever: Aluminum brake lever+ switch
Balance Device: Yes (Anti-swerve device)
Gear System:Shimano Nexus 3 inter hub gear (Optional)
ecoway tilting electric tricycle
jateureka2
Re: Tilting Electric Tricycle
Curious about how the rear chain drive functions when the front tilts and the rear stays up right.
I can see a chain tensioner but there has to be more to it than that.
Does anyone have any more pics?
E-BIKES: [1]Ezee Sprint [2]Aprilia Enjoy Racing [3]eLation V2 e-bike kit on Trek 4100 [4]Bafang BBS01 kit on Fluid Momentum [5] FreeGo Hawk
E-SCOOTER: 2012 ZEV 7100 LR, 84V 60Ah nominal battery with 28 series GBS LFP cells
E-MOTORCYCLE: 2011 Zero S,
empoweredebikes
empoweredebikes's picture
If you are interested in tilting electric tricycles you might also want to check out the Cavalo by Empowered Ebikes
Cavalo tilting electric trike
Follow the link to check out this electric tricycle
Similar to the trike shown above, the Cavalo's front wheel can tilt. This allows the trike to lean from side to side as if it only had two wheels, dramatically increasing the handling characteristics and practically eliminating the risk of tipping over.
The main differences between the Cavalo and the ebike listed above are:
1. More powerful motor - 350W
2. Added front basket
You can also view a clip on you tube of the Cavalo electric tricycle
Quality Ebikes at reasonable prices
http://www.empoweredebikes.com
