Homebuilt 48V controller ??
2 posts / 0 new
zip
has anyone ever come across schematics for building 48V scooter controller?
tnx in advance.
Spaceangel
Re: Homebuilt 48V controller ??
If you know enough electronics then the kits from Hosfelt and All Electronics do good for 48 volts. That is how I got my experience with PWM controllers to use as light dimmers and battery chargers and of course what they were designed for ~ Motors. The kits come designed for one transistor or one MOSFET but the final pass device can be paralleled if you use a set of FETS vs transistors.
Some of the cheaper kits require a separate power supply for driver board but again it can be modified also.
Rus
KB1UKU
