Needed: Dead charger for XB-600.
Buzzer
Buzzer's picture
Last seen: 13 years 20 hours ago
I took apart the charger for my XB-600 because it was sounding a little noisy after it fell off the carpeted floor of my scooter onto the ground, a distance of just a few inches. It still works. Anyway, when I opened it up, I noticed that the ventilation fan is missing two of its fan blades. I found one blade, but not the other. The easiest solution would be replace the fan. Does anyone have a dead XB-600 charger they no longer need? Anybody want to sell the fan out of it, or the whole charger so I can use it for parts? Because my charger still works, I don't really want to pay for a whole new charger.
Spaceangel
Re: Needed: Dead charger for XB-600.
What size is fan? HOLE to hole? width? etc? I have lots of smoked chargers but not for small XB-600 stock bike etc. I also have a fair collection of fire alarm power supplies using small fans also. Hosfelt and ALL electronics has a large collection of fans in the dollar and $2.00 range. Little dinky fans like in small computers of the 486 and P-1 era. I found out most of my failures were seat closed on charger when it rained and it got too hot under seat and fried transistors or diodes. Even though I drive "small" bikes they use 60 volts now and I use 12 ampere charger on CSB EVX-12200 battery pack. Wicked charge times now.
Maybe others on V will need to know current of broken motor and voltage too.
KB1UKU
poepad
Don't buy any futher away than you can drive to and return it.
Buzzer
Buzzer's picture
Fan is square shaped, 1-15/16" x 1-15/16" (not quite 2" x 2"), and 7/16" thick. DC 12V, 0.09A. Brand name is Cool King, made by Xin Ying Jia Motor Industry Co., LTD. There are two numbers on it, I don't know if they are part numbers, or what: CK12S5010M and CTE:06060039. Made in China, of course. It has a black wire and a red wire going to a small 2-pin plug. I'll do a search for one if I need to, but the quickest and easiest solution would be if someone already has a dead XB-600 charger. I'd hate to see anyone else spending a lot of time on this. My alternate plan is for me to fabricate the two missing fan blades and just glue them on.
Buzzer
There are three kinds of people: Those who make things happen, those who watch things happen, and those who wonder what happened.
Buzzer
Buzzer's picture
Thanks for the link! I also did a Google search of the fan specs, with the dimensions in millimeters. Several other fans came up that should also work, although they all have a third yellow wire which is apparently used on many devices to regulate the fan speed. I should be able to remove that wire and recycle the two-prong female plug from my existing fan to make the replacement work. Thanks for your help! If anyone has a dead XB-600 charger with an intact fan they don't want, I'd still be interested. Otherwise, I'll just go ahead and get a new fan.
Buzzer
