BionX Charging Problem
2 posts / 0 new
Jerry the Spinner
Jerry the Spinner's picture
I just got home from my commute . The battery gage shows half empty. However, when I go to charge the battery it goes from yellow to green in only 5 seconds. When I check the battery gage it shows half empty. For some reason the battery charger thinks the battery is charged even though it is half empty.
vgregdo
Re: BionX Charging Problem
I just started having the same problem today. Did you figure out how to fix this?
Thanks.
